XJ Rebuild...
be careful... i put all greaseable joints in my shaft and the fill nipple off of the middle Ujoint self clearanced. basically it didnt have room to articulate, and the nipple got ripped off. i didnt notice until recently. but i dont see any orientation where a greasable joint would work properly. does yours rotate freely?
care to take a picture of its orientation?
They make U joints that have a zert in the cap. They are a pain in the walt though!!!
Been there the first time I rebuilt my dive shaft years ago... then I found these u joints, (spicer 280) they have the small grease zerts in the caps, super easy to grease and they were only 13 bucks on rock auto...
In other news, still waiting for that TNT replacment arm.....
Got the replacment arm in, had to go pick it up from UPS because TNT required a signature for some reason.
It needs dialed in, so I need some help. As it sits right now I think the axle is a little far forward. The diff is at 8 degrees putting the caster at -1 degree but the pinion angle looks almost right on. The main concern is the sway bar link hitting the coil on the passenger side... The lowers and uppers are alll the same lengths side to side and the axle looks centerd, I havent tried reseting it. SO what do you guys think/ recommend.
Got my BOR 4.5 inch springs, out with the nasty bastard packs..
will have to do some clearencing on my bump stop plate, luckey it just dented the shock.
Would of been done tonight but the passenger side sleeves were froze to the bolts so I had to cut them out and no one is open that had a replacment bolt, I believe is a 14x1.25 will have to source one tommorow.
Should go together quick...
And I got these to replace my mismatched chrome ones,
So I started searching for what size the leaf spring bolt was and ran across a post saying that the lower control arm bolts are the exact same which I had laying around from the recent tnt install. Thanks Kastein! So 20 miniutes later I had it together...
Its about an inch lower which is fine, but the ride is so much smoother, I cant wait to flex it out.
