XJ Lift Companies
IanFarnes
Montana
COMPLETE LIST OF XJ LIFT KITS OUT THERE W/ LINKS AND ROUGH PRICING!--- Hey guys... here is a list of lift setups for you new guys who are not sure about what lift kits are available or you older guys looking to upgrade. I tried to get links directly to the manufacturer as they usually have the best pictures/info. The prices are by no means set and if you shop around you should be able to find them cheaper. I hope this helps you gives you some new ideas about kits you did not know were out there. Enjoy! :o
** There are some kits available on websites that are no longer in production EX: Rubicon Express 7.5", Black Diamond Lifts etc. Those will not be in the list as I don't know how long they will be available. There are also alot of places that make hybrid kits pieced together from multiple companies).. I will try to get some of those on here as they are usually cheaper
IF A LINK NO LONGER WORKS/PRICE IS WRONG/I'M MISSING SOMEBODY, PM ME AND I WILL FIX IT. THANKS!
Listed first by lift size then by price.
The Baby Lifts (0-2.9")
TOUGH DOG SUSPENSION
http://www.toughdogdealer.com.au/xjcherokee.htm#suspension
1.57"- 2060-1800$ This kit includes: Coil Springs, Leaf Springs, Transmission Spacer, Shocks, Bushings, Ubolts and Hardware. The price changes depending on what shocks you get (Nitro, Foam Cell, Adjustable)
IRONMAN SUSPENSION
http://www.ironman4x4.com/html/jeep/20.html
1.76"-1100$ This Kit Includes: 4 Foam Cell Shocks, Full Leaf Springs, Coil Springs, Ubolts and Hardware.
OLD MAN EMU
http://www.4x4groupbuy.com/store/xj-old-man-emu-lift-2-p-2172.html
2"- 839$- Old Man Emu does not have a home page and the ARB site is hard to navigate. This Kit Includes: 4 OME shocks, Coil Springs, Leaf Springs, and a set of JKS Quick Disconects. People who have Old Man Emu love them.
SUPER LIFT
http://www.superlift.com/Catalog.asp?P=K369&V=265
2.5"- 510$- This kit lifts you 2.5" of lift and includes: Tubular Lower Control Arms, Add-A-Leaf, "Super-ride" Shocks, Hardware and a "Speed Sensor Calibrator." Superlift has been around for along time.
RANCHO
http://www.gorancho.com/suspension.php?make=Jeep&model=84_01_jeep_cherokee_xj#lift
2.5"- 500$ This Kit Includes: Shocks, Front Coils, Control Arms, Add-A-Leafs, UBolts, Bushings and Hardware.
BDS SUSPENSION
http://bds-suspension.com/product?ma=7&mo=29&ty=38&yr=1984-2001
2"- 431$ BDS offers this kit and 2 under it (1.75" lift and .75" lift). This kit includes: Coil Springs, Add-A-Leaf, Shocks, and Hardware. BDS has a great reputation.
ROCK LIZARD FAB
http://www.rocklizardfabrications.com/lizard_lift_kits.htm
2.5"-400$ This kit includes:Four Leaf Spring Pack, Coils, Long AAL, Spring Isolators, Spring Clamps, Center Pins, and U-Bolts
2"-300$ This kit includes: Coils, Long AAL, Leaf Spring Clamps, Center Pins, and U-Bolts
SKY JACKER
http://skyjacker.com/product.php?ProdID=26863
2"- 390-360$- This kit only comes with shackles, shocks and spacers. Sky Jacker has a few different 2" kits, but all are almost the same.
RUBICON EXPRESS
http://www.rubiconexpress.com/Lift-...NOMY KIT&Manufacturer_PQ=Rubicon Express#tab5
2"- 260$ Kit Includes: Shocks, Spacers, Add-A-Leafs and a Brake Line.
ZONE OFFROAD
http://zoneoffroad.com/product?ki=31&gr=-1
2"- 251$ Kit Includes: Add-A-Leaf, Spacers, and Hardware. Not a bad kit for the price.
ROUGH COUNTRY
http://www.roughcountry.com/jeep_xj_1.html
1.5" 250$ Kit comes with shackles, Spacers, shocks, and bolts
FAT BOB'S GARAGE
http://4x4.fatbobsgarage.com/jeep-cherokee-xj-2-front-15-2-rear-w-performance-8000-series-shocks-1984-2001-p7510.aspx
2"-190$ Fat Bob offers a few different budget lifts. This is his most expensive 2" and includes Shocks, Shackles, Spacers and Hardware.
http://4x4.fatbobsgarage.com/jeep-cherokee-xj-2-front-lift-kit-with-15-2-adjustable-rear-shackles-1984-2001-p1984.aspx
2"-80$ This is his cheapest. This kit includes Hardware, Front Spacers and Adjustable Shackles.
TOMKEN MACHINE
http://www.tomken.com/catalog.php?search=terms%3D%26model%3DXJ%26year%3D1999%26cat%3Dliftkits
2" 178.96$ Kit comes with Spacers, Blocks, Ubolts, Shock Extensions and Brake Extensions.
DAYSTAR
www.daystarweb.com/productdetail.php?productID=354
1.75"-150$ Kit Includes: Spacers and Shackles.
TERRAFLEX
http://www.teraflex.biz/xj-cherokee-2-inch-budget-boost.html
2"-150$ Kit Includes: Spacers and Shackles.
TRAIL MASTER
http://www.trailmastersuspension.com/details.php?Application=Jeep&Part_Number=JC240G&Title=JEEP%20CHEROKEE%20COIL%20SPRING%20/%20SHACKLE%20LIFT%20W/%20GREASABLE%20SHACKLES&Active=Yes
2"-120$ Kit Includes: Spacers and Shackles.
RUSTY'S OFFROAD
http://www.rustysoffroad.com/jeep-suspension/jeep-suspension-lift-kits/xj-cherokee-84-01-jeep-suspension-lift-kits/rustys-xj-cherokee-budget-boost-spacer-shackle.html
1.75"- 99$ Kit Includes: Spacers and Shackles. Rusty's also offers a budget kit with Add-A-Leafs.
Pre-School Lifts! (3-3.9")
TNT CUSTOMS
http://www.tntcustoms.com/rock-tek/3.5/suspension_solution/Jeep_Cherokee_XJ.aspx
3.5"-2,395$ Kit Includes: High Clearance Belly Pan, Bent Y-Link Arms, Leaf Springs, Drop Track Bar, Bump-Stops, Sway Bar Disconnect, Steel Braided Brake Lines, Pitman Arm. TNT is generally considered one of the best.
SKY JACKER
http://skyjacker.com/product.php?ProdID=26240
3"- 1360$-600$. Sky Jacker offers a few different 3" kits. The link is to the most expensive kit which includes: Leaf Springs, Lower Control Arms, Front Coils, Track Bar Bracket, and Hardware.
OLD MAN EMU
http://www.jeepinoutfitters.com/scripts/prodView.asp?idproduct=429
3"- 894$ Kit Includes: Shocks, Leaf Springs, Coils, JKS Quick Disconects and Hardware.
JKS MFG
http://jksmfg.com/i-9056832-cherokee-xj-comanche-mj-1984-2001-front-adjustable-coil-spacer-pro.html
1.375-3.25"- 885$ Kit includes: This is an adjustable spacer lift/bump stop. You can go between 1.375 and 3.25" of lift by simply turning the dial. Also has a hydraulic bump stop. Comes with all hardware. Does not include anything to lift the rear.
RUBICON EXPRESS
http://www.rubiconexpress.com/Lift-Kits-Suspensions-Shocks/Jeep-Suspension.aspx?t_c=1&t_s=38&t_pt=3533&vgID=12&Rubicon%20Express%20Suspension%20Type_PQ=SUPER-FLEX%20SHORT%20ARM&Manufacturer_PQ=Rubicon%20Express#tab3
3.5"- 760-450$ Rubbicon express offers 4 different 3.5" kits. Two of them are "superflex kits" and two are "super-ride kits". Most of the kits include: Coils, Lower Control Arms, Sway Bar Links, Brake Lines, and either Add-A-Leaf or Full Leaf Packs.
TUFF COUNTRY
http://www.tuffcountry.com/suspension-kit/jeep-1987-01-cherokee-lift-kits.html
3.5"-740-530$ TuffCountry offers two kits for the XJ. The cheap one comes with blocks in the rear while the more expensive one comes with full leaf springs. Both kits include: Shocks, Coils, UBolts, Extended (or Adjustable) Lower Control Arms, Transfer Case Drop Kit, Track Bar Bracket and Hardware.
WARRIOR PRODUCTS
http://www.warriorproducts.com/catalog/84-01-jeep-cherokee-xj/suspension/xj-cherokee-suspension-lift-kits/
3"-660$- This Kit Includes: Shackles, Shocks, Front Coils, Control Arms, Sway Bar Links, and Hardware.
BDS
3"- 577$- Kit Includes: Shocks, Coils, Transfer-Case Drop, Sway Bar Links, Track Bar Bracket, and Blocks.
PRO COMP
http://www.procompusa.com/prodDetail.aspx?partNo=EXPK3058B&catID=1&subCat=38&ptID=5491&plID=1808
3"- 573$- Kit Includes: Coil Springs, Sway Bar Links, Lower Control Arms, Brake Lines, Add-A-Leafs, and Shocks.
RUGGED RIDGE "ORV"
http://www.ruggedridgeoffroad.com/jeep-cherokee-orv-lift-kits.php
3"- 549$ Kit Includes: Shocks, Coils, Lower Control Arms, Track Bar Bracket, and Hardware.
FULL TRACTION
http://www.full-traction.com/detail.php?MODELID=4&MAKEID=1&TYPEID=1&PRODUCTID=97&NOTES=20
3.5"- 529$ This Kit Includes: Control Arms, Add-A-Leafs, Front Coils, Sway Bar Quick Disconnects, UBolts and Hardware.
ZONE OFFROAD
http://zoneoffroad.com/product?ki=436&gr=-1
3"-510$ Kit Includes: Full Leaf Springs, Shocks, Ubolts, Coil Springs and Hardware.
http://zoneoffroad.com/product?ki=34&gr=-1
3"- 291$ Kit Includes: Shocks, UBolts, Add-A-Leafs and Hardware.
RUSTY'S OFFROAD
http://www.rustysoffroad.com/jeep-suspension/jeep-suspension-lift-kits/xj-cherokee-84-01-jeep-suspension-lift-kits/rustys-xj-cherokee-3-spring-pack-kit.html
3"- 438-265$ Rustys offers two 3" lifts, one of them (438$) comes with full leaf springs while the other (265$) comes with Add-A-Leaf. Both Kits Include: Front Coils, Shocks, UBolts, Rear Brake Extension and Hardware.
REVTECH INDUSTRIES
http://www.revtek.com/jeepsusp.asp#570
3"-425$ This Kit Includes: Shocks, Add-A-Leafs, Front Coils and Hardware.
ROUGH COUNTRY
http://www.roughcountry.com/jeep_xj_3x.html
3"- 345-255$ Rough Country has two 3" kits. Both Kits Include: Add-A-Leafs, Sway Bar Brackets, Shocks, and Hardware. The more expensive kit also includes lower control Arms.
ROCK KRAWLER
http://www.rockkrawler.com/index.php?r_intro=no
(You have to navigate to the XJ section... It won't let me direct link.)
3.0"- 380$ This Kit ONLY Includes: Front Springs and Rear Shackles.
IRON ROCK OFFROAD
http://www.ironrockoffroad.com/Merchant2/merchant.mvc?Screen=PROD&Store_Code=IROR&Product_Code=IR-X3LK&Category_Code=XLK
3"- 340$ Kit Includes: Front Coils, Add-A-Leaf With Clamps, Shocks, Transfer Case Drop, Sway Bar Links, Rear Brake Extension and Hardware.
FAT BOB'S GARAGE
http://4x4.fatbobsgarage.com/jeep-cherokee-xj-3-lift-kit-w-performance-8000-series-shocks-1984---2001-p7568.aspx
3"-240$- Fat Bob's offers a bunch of different budget options for lifting your XJ. This is his most expensive. This Kit Includes: coil springs, add-a-leaf springs, shocks and a track bar bracket.
http://4x4.fatbobsgarage.com/jeep-cherokee-xj-3-lift-kit-4wd2wd-1984-2001-p3833.aspx
3"-90$ This is his cheapest. This kit has front spacers, hardware and a rear add-a-leaf.
ROCKY ROAD
http://www.rocky-road.com/xjbudget.html
3"-149$ This Kit Includes: Blocks, Shackles, Bar Pin Relocators and Coil Spacers. For a little extra, you can also get a set of shocks.
The Average Lifts (4.0-5.9")
ROCK KRAWLER
(Rock Krawler will not let me direct link on their site. You will have to navigate to the XJ section.)
4.5" 3000-1050$ Rock Krawler offers 4 different 4.5" Kits. They range from the most expensive (Rear Coil Conversion, Long Arms all the way around) to a short arm kit using your stock upper control arms. Their stuff is very high quality but very expensive.
SYNERGY SUSPENSION
http://synergysuspension.com/Synergy-Suspension-Jeep-XJ-Complete-Long-Travel-Front-Rear-Kit-4-Link-Front-p-25694.html
5.5"-2980$- I had to add the parts to make this a complete kit resulting in the elevated price. Just the arms is 1500$. This Kit (with the Springs/brake lines) Includes: Front and Rear Coil Springs, Complete Front and Rear Long Arms w/ Brackets, A Drop Pitman Arm, Track Bar and Hardware.
TNT CUSTOMS
http://www.tntcustoms.com/Rock-Tek/4.5Suspension_Solution/Jeep_Cherokee_XJ.aspx
5.5"- 2599$ TNT is arguably one of the best. They have two kits in this category. One is 5.5", the other is 4.5". Both Kits Include: Belly Pan and Transfer-Case Skid Plate, Y-Link Long Arms, Leaf Springs, Track Bar and Bracket, Braided Brake Lines, Bumpstops, Quick Disconnects, Pitman Arm and Hardware.
http://www.tntcustoms.com/Rock-Tek/4.5_Suspension_Solution/Jeep_Cherokee_XJ.aspx
4.5"- 2,550$ Same as Above Just Smaller :o
BDS
http://bds-suspension.com/product?ma=7&mo=29&ty=38&yr=1987-2001&kid=468H
4.5"-2400$ This Kit Includes: 4-link Long Arms, New Cross Member, Shocks, Leaf Springs, Coils, Shackles, Track Bar, Sway bar Links, Brake Lines and Hardware.
4.5"-1740$ This Kit Includes: 4 Short Control Arms, Full Leaf Packs, Coils, Shocks, Shackle, Track Bar, Swar Bar Links, Brake Lines and Hardware.
SKY JACKER
http://skyjacker.com/product.php?ProdID=26269
4.5"- 2160$ SkyJacker has like 7 different 4.5" lifts. This is the most expensive. The Kit Includes: 4-link RADIUS Long Arms with separate mounting brackets, Full Leaf Packs, Brake Lines, Shackles, Steering Stabilizer, Front Coils, Sway Bar Links, Pitman Arm, UBolts, Shocks and Hardware.
CLAYTON OFFROAD
http://claytonoffroad.com/product_info.php/cPath/18_66/products_id/113
4.5"- 2100$ Clayton kits get great reviews. I don't think I have ever heard a complaint about them. This Kit Includes: Long Arms, Crossmember, Adjustable Trackbar, Adjustable Control Arms, Shims, Spring Retainers, Sway Bar Disconnects, Coils, Stainless Brake Lines, Ubolts and Hardware.
RUBICON EXPRESS
http://www.rubiconexpress.com/Lift-Kits-Suspensions-Shocks/5-5-Extreme-Duty-Long-Arm-Suspension-System-No-Shocks.aspx?t_c=1&t_s=38&t_pt=3533&t_pn=R%2fERE6300
5.5"- 2050$ This is their Long Arm Kit. This Kit Includes: Front Coils, Long Arms, 3-Piece CrossMember, Full Leafs, Brake Lines, Sway Bar Disconnects, Shackles, Track Bar/Bracket, UBolts and Hardware.
http://www.rubiconexpress.com/Lift-Kits-Suspensions-Shocks/5-5-Extreme-Duty-Short-Arm-Suspension-System-No-Shocks.aspx?t_c=1&t_s=38&t_pt=3533&t_pn=R%2fERE6200
5.5"-1500$ This is their standard kit. This Kit Includes: Sway Bar Disconnects, Coil Springs, Bump-Stops, Leaf Springs, Brake Lines, Adjustable Trackbar w/Bracket, Shackles, Control Arms and Hardware.
http://www.rubiconexpress.com/Lift-Kits-Suspensions-Shocks/4-5-Super-Flex-Short-Arm-Suspension-System-with-Rear-Add-A-Leafs-No-Shocks.aspx?t_c=1&t_s=38&t_pt=3533&t_pn=R%2fERE6111
4.5"- 935$ They have two 4.5 Inch kits. I am only going to link one. This is the cheapest of the two. This Kit Includes: Add-A-Leafs, Control Arms, Adjustable Track Bar, Sway Bar Disconnects, Brake Lines, Ubolts and Hardware.
TRAIL MASTER
http://www.trailmastersuspension.com/details.php?Application=Jeep&Part_Number=J4720SSV&Title=JEEP%20CHEROKEE%20XJ%204
4"- 1450$ This Kit Includes: Full Leaf Springs, Coil Springs, All Four Controll Arms (Short), Shocks, TrackBar, Brake Lines, Sway Bar Links, UBolts and Hardware.
Trail Master Does offer a kit similar to the Zone kit but without shocks and with AAL for 500 bucks.
IRON ROCK OFFROAD
http://www.ironrockoffroad.com/Merchant2/merchant.mvc?Screen=PROD&Store_Code=IROR&Product_Code=IR-X5CPK&Category_Code=XLK
5.5"-1400$- This Kit Includes: Radial Long Arms, 3-Piece CrossMember, Full Leaf Springs, Front Coils, Shocks, Sway Bar Links, Track Bar w/Bracket, Brake Lines and Hardware.
http://www.ironrockoffroad.com/Merchant2/merchant.mvc?Screen=PROD&Store_Code=IROR&Product_Code=IR-X4CPK&Category_Code=XLK
4"- 1050$- This Kit is the same as above but has Add-A-Leafs instead of full packs. It is also an inch and a half shorter :o
http://www.ironrockoffroad.com/Merchant2/merchant.mvc?Screen=PROD&Store_Code=IROR&Product_Code=IR-X4LK&Category_Code=XLK
4"- 450$- This Kit includes: Add-A-Leafs, Front Coils, Shocks, Transfer Case Drop Kit, Sway Bar Links, Brake Lines and Hardware.
SUPER LIFT
http://www.superlift.com/Catalog.asp?P=K788&V=263
4"- 1300$ This is their "Rock Runner" Kit. This Kit Includes: "Swivel" Control Arms, Adjustable Track Bar, Front Coils, Full Leafs, Transfer Case Drop, Sway Bar Links, Shocks, Ubolts and Hardware.
http://www.superlift.com/Catalog.asp?P=K787&V=263
4"-1020$- This is their "Standard" Kit. This Kit Includes: Control Arms, Adjustable Track Bar, Front Coils, Full Leafs, Transfer Case Drop, Sway Bar Links, Shocks, Ubolts and Hardware.
ROUGH COUNRTY
http://www.roughcountry.com/jeep_xj_4xla.html
4.5"- 1300$- Rough Country has a few different 4.5" kits. This is the Long Arm Kit. This Kit Includes: Long Arms, Front Springs, CrossMember, Drop Pitman Arm, Sway Bar Disconnects, Transfer Case Skid Plate, Adjustable Track Bar, Shocks, Ubolts and Hardware.
http://www.roughcountry.com/jeep_xj_4x.html
4.5"- 830$ This is their "X-series" Kit. This Kit Includes: Adjustable Short Control Arms, Front Coils, Transfer Case Drop Kit, Sway Bar Disconnects, Adjustable Track Bar, Brake Lines and Hardware.
CURRIE ENTERPRISES
http://currieenterprises2.reachlocal.net/cestore/product.aspx?id=3504
4.5"- 1280$ Curie Has Been A Name In Jeeps Forever. I believe their lift kits are rather new. They have them for all different axle types but they are all pretty much the same. This Kit Includes: Coil Springs, Track Bar, Control Arms (With Johnny Joints), Full Leafs, Bushings, Bump Stops, Ubolts and Hardware.
TOMKEN MACHINE
4"- 971.20$- This kit comes with Rear leafs with bushings, Front coils, Sway bar mounts, Front Bump stops, Rear Bump stops, 1" trans case drop, Brake line ext, Axle shims, Lower adj control arms, Upper adj control arms, and U-bolts.. Tomken has been around for along time and recently re-vamped their products.
FABTECH
http://www.fabtechmotorsports.com/products/cart.php?m=product_detail&p=69&display=JEEP
4"- 970$ This Kit Includes: Add-A-Leafs, Coil Springs, Shocks, Control Arms, Sway Bar Links and Hardware.
ZONE OFFROAD
http://zoneoffroad.com/product?ki=439&gr=-1
4.5"-749$ This Kit is the more expensive Zone kit. It Includes: Full Springs, Control Arms, Shocks, Ubolts, Coil Springs, Shackles, Sway Bar Links and Hardware.
http://zoneoffroad.com/product?ki=35&gr=-1
4.5"- 495$- This Kit Includes: Control Arms, Shocks, Add-A-Leafs, Sway Bar Links, Brake Line Relocation Brackets, UBolts and Hardware.
RUSTY'S OFFROAD
http://www.rustysoffroad.com/jeep-suspension/jeep-suspension-lift-kits/xj-cherokee-84-01-jeep-suspension-lift-kits/rustys-xj-cherokee-4-5-spring-pack-kit.html
4.5"- 670$- This Kit Includes: Full Leaf Springs, Front Coils, Control Arms, Adjustable Track Bar, Shocks, UBolts and Hardware.
http://www.rustysoffroad.com/jeep-suspension/jeep-suspension-lift-kits/xj-cherokee-84-01-jeep-suspension-lift-kits/rustys-xj-cherokee-4-5-add-a-leaf-kit.html
4.5"-590$ This kit is the same as above only it has Add-A-Leafs instead of Full Packs.
The Manly Lifts (6.0-7.9")
CLAYTON OFFROAD
http://claytonoffroad.com/product_info.php/cPath/18_66/products_id/107?osCsid=b58aa693968d7bb878069bd4ae8f9eab
6.5"- 3550$- This Kit Includes: 8 Fully Adjustable Long Control Arms, Rear Coil Conversion, Stainless Brake Lines, Skid Plate, Adjustable Track Bar, Front and Rear Coils, Quick Disconnects, Rear Axle Bracket, Axle Truss and Hardware.
** Requires Welding
http://claytonoffroad.com/product_info.php/cPath/18_66/products_id/329
6.5"-2350$- This Kit Includes:3 Link Long Arm Setup, Full Leaf Springs, Spring Retainers, Coil Springs, Stainless Brake Lines, Adjustable Track Bar, JKS Quick Disconnects and Hardware.
ROCK KRAWLER
(I cannot direct link on RKs website so you will have to navigate to the XJ Section)
6.5"-3180$- This Kit Includes: 8 Adjustable Control Long Arms, Rear Coil Conversion, Custom Brackets, Adjustable Track Bar, Front Coil Springs, Brake Lines, Quick Disconects and Hardware.
** REQUIRES: Welding, TJ 2" Rear Coil Spring, New Exhaust System
6.5"- 1900$- Cheaper Kit that Includes: Add-A-Leafs, Front Long Arms and Brackets, Adjustable Boomerang Shackles, Front Coils, Brake Lines, Adjustable Track bar and Hardware.
BDS
http://bds-suspension.com/product?ma=7&mo=29&ty=38&yr=1987-2001&kid=455H
6.5"- 2540$- This Kit Includes: 4 Link Front Long Arms and Custom Crossmember, Front Coils, Shocks, Rear Leaf Springs, Adjustable Track bar, Brake Lines, Quick Disconnects, Shackles and Hardware.
SKY JACKER
http://skyjacker.com/product.php?ProdID=26284
6"- 2310$- SkyJacker has 3 different 6" lift kits. They are all almost the same so I am only going to link one. This Kit Includes: Radius Long Arm Setup w/ Mounting Brackets, Front Coils, Leaf Springs, Shackles, Sway Bar Links,Shocks, Brake Lines, Track Bar and Hardware.
TOMKEN MACHINE
6"-2126$- Kit Includes: 4 Link Long Arms, Axle shims, Front bump stops, Rear bump stops, Front/Rear brake lines, Set of 4 U-bolts, Upper controll arm mounts and brace, Lower controll arm trany mount, Drop Pitman, Front 6" coils, Rear 6" Leaf sprins ( bushings included)
FROEHLICH SUSPENSION
http://froehlichsuspension.3dcartstores.com/65-Kit-and-Kaboodle_p_20.html
6.5"-1843$ Kit Includes: 3 Link Long arms (50$ more for 4-link), Drop Pitman Arm, Add-A-Leaf with Blocks/Shackles and Hardware. For some extra cash, you can add Full Leafs, Shocks, and a Beefed up Steering.
FULL TRACTION
http://www.full-traction.com/detail.php?MODELID=4&MAKEID=1&TYPEID=1&PRODUCTID=98&NOTES=9,10
6"-1795$- This Kit Includes: 4 Link Long Arms w/Brackets, Shackles, Leaf Springs, Coil Springs, Quick Disconnects, Brake Lines, Adjustable Track Bar, Heim Joints and Hardware.
RUSTY'S OFFROAD
http://www.rustysoffroad.com/jeep-suspension/jeep-suspension-lift-kits/xj-cherokee-84-01-jeep-suspension-lift-kits/rustys-xj-cherokee-6-5-long-travel-kit.html
6.5"-1740$- This Kit Includes: Radius Long Arm System (Two Upper and Two Lower), Cross Member, Shocks, Coil Springs, Leaf Springs, Adjustable Track Bar, Drop Pitman Arm, Stainless Brake Lines, Shims and Hardware.
http://www.rustysoffroad.com/jeep-suspension/jeep-suspension-lift-kits/xj-cherokee-84-01-jeep-suspension-lift-kits/rustys-xj-cherokee-6-5-spring-pack-kit.html
6.5"-1100$- This is the Cheaper of their two 6.5" kits. This Kit Includes: 4 Short Control Arms, Coil Springs, Leaf Springs, Shocks, Adjustable Track Bar, Quick Disconnects, Stainless Brake Lines and Hardware.
IRON ROCK OFFROAD
http://www.ironrockoffroad.com/Merchant2/merchant.mvc?Screen=PROD&Store_Code=IROR&Product_Code=IR-X6CPK&Category_Code=XLK
6.5"-1450$- This is the kit I run and I love it! Sorry for the small piece of opinion but I had to throw it in there. This kit comes with: 3-Arm Radial Long Arms, Leaf Springs, Shackles, Sway Bar Links, Adjustable Track Bar, 3-Piece Crossmember, Shocks, Coil Springs, Hardware and Great Customer Service :o
http://www.ironrockoffroad.com/Merchant2/merchant.mvc?Screen=PROD&Store_Code=IROR&Product_Code=RC-696N2&Category_Code=XLK
6.5"- 900$- This is their cheaper kit. This kit includes: Coil Springs, Leaf Springs, 4 Adjustable Short Control Arms, Shackles, Adjustable Track Bar, Quick Disconnects, Drop Pitman Arm, Shocks and Hardware.
ROUGH COUNTRY
http://www.roughcountry.com/jeep_xj_6xla.html
6"- 1450$- This Kit Includes: Radial Long Arms, CrossMember, Leaf Springs, Coil Springs, Shackles, Brake Lines, Quick Disconnects, Adjustable Track Bar, Ubolts and Hardware.
http://www.roughcountry.com/jeep_xj_6x.html
6"-900$ This is the cheaper of their 6" lifts. This Kit Includes: Coil Springs, Leaf Springs, 4 Adjustable Short Control Arms, Shackles, Adjustable Track Bar, Quick Disconnects, Drop Pitman Arm, Shocks and Hardware.
JEEP PARTS GUY
http://jeeppartsguy.com/products/?view=product&product_id=64
6.5"- 756$- This Kit is piece together from a few different brands. It Includes: Coil Springs, Upper and Lower Adjustable Control Arms, Transfer-Case Drop, Adjustable Track Bar, Pitman Arm, Brake Line Relocation Bracket, Leaf Springs, Shackles, Brake Line Relocation Bracket and Hardware.
The "Compensation Lifts" (8.0" and up) :D
CLAYTON OFFROAD
http://claytonoffroad.com/product_info.php/cPath/18_66/products_id/332?osCsid=6508c9277b5d37d38cd6e69ace2aa353
8"- 3510$- This kit Includes: A 3 Link Front/4 Link Rear Long Arm Kit, 3 Piece Crossmember, HD Trackbar, 3-Link Bridge for D30 (Front), Rear Crossmember, Coil Springs (All 4), Drop Pitman Arm, Coil Retainers, Brake Lines, Quick Disconects and Hardware.
http://claytonoffroad.com/product_info.php/cPath/18_66/products_id/330
8"-2500$ This kit is the same as above but only the front. It is a 3-Link Long Arm Kit and includes Leaf Springs in the back.
BDS
http://bds-suspension.com/product?ma=7&mo=29&ty=38&yr=1987-2001&kid=478H
8.5"-2824$ This kit includes: 4-Link Long Arms, CrossMember, Coil Spacers, Shocks, Spring Retainers, Leaf Springs, Brake Lines, Shackles, Lift Blocks, Sway Bar Disconnects, Bump Stop Extensions, Drop Pitman Arm and Hardware. This kit has great reviews.
SKY JACKER
http://skyjacker.com/product.php?ProdID=26302
8"-2470$ SkyJacker has three 8" lift kits. There are small differences (both in price and equipment) This kit has: Radial Long Arms w/ Brackets, Coil Springs, Leaf Springs, Quick Disconnects, Shocks, Shackles, Brake Lines, Pitman Arm, Bump Stops and Hardware.
TOMKEN MACHINE
http://www.quadratec.com/products/76016_841.htm
(I'm not sure why it's not listed on their site. They have pictures of it but it is not found in the catalog.)
8"-2100$ This kit comes with Coil Springs, Leaf Springs, 4 Adjustable Control Arms, Brake Lines, Blocks and Hardware.
RUSTY'S OFFROAD
http://www.rustysoffroad.com/jeep-suspension/jeep-suspension-lift-kits/xj-cherokee-84-01-jeep-suspension-lift-kits/rustys-xj-cherokee-8-long-travel-kit.html
8"- 1900$- This is Rusty's 8" kit. The kit includes: Radial Long Arms, 3 Piece Crossmember, Front Coils, Leaf Springs, Shocks, Shackles, Drop Pitman Arm, Extended Brake Lines, Adjustable Track Bar, Ubolts and Hardware.
IRON ROCK OFFROAD
http://www.ironrockoffroad.com/Merchant2/merchant.mvc?Screen=PROD&Store_Code=IROR&Product_Code=IR-X8CPK&Category_Code=XLK
8"-1550$- Kit Includes: 3 Link Radius Long Arms, 3 Piece SubFrame, Double Shear Track bar, Leaf Springs and Add-A-Leaf, Shocks, Ubolts and Hardware.
BUILDER PARTS/LONG ARMS/ETC
SERIOUS OFFROAD
http://www.seriousoffroadproducts.com/Serious-Offroad/Serious-Suspension/SERIOUS-OFFROAD/Serious-LongArms-84-01-XJ-Upgrade-Kit-For-Your-Existing-4-7.5-Short-Arm-Lift?cPath=419_1621&
750$- Made by Serious Offroad, this kit allows you to add long arms to your 4"-7.5" lift kit. This kit comes with Teraflex Joints, a beefy crossmember, and all the equipment needed to mount it.
SEXTON OFFROAD
http://sextonoffroad.com/i-8181742-tubular-radius-arms.html
745$ Made by Sexton Offroad, this kit allows you to change your stock short arms to a radius long arm system.
ROCK KRAWLER
(You have to navigate to the XJ Section. It won't let me direct link)
1500$- Rear Coil Conversion. This kit allows you to remove your rear Leaf Springs completely and have Long Arms all the way around. It comes with/They Sell Everything you need to put it on. Rock Krawler also sells a ton of other parts for the XJ like: "Bomb-Proof" Track Bar, Coils, Shocks, A Few Different Long Arm Upgrades/Kits etc.
IRON ROCK OFFROAD
http://www.ironrockoffroad.com/Merchant2/merchant.mvc?Screen=CTGY&Store_Code=IROR&Category_Code=XSP
$Varies- Iron Rock Offroad offers many different builder parts including: Shackles, Coils, Leaf Springs, Spacers, Bushings, Ubolts, Shims ETC.
JKS MANUFACTURING
http://store.jksmfg.com/merchant2/merchant.mvc?Screen=CTGY&Store_Code=JKS01&Category_Code=CherokeeXJ
$Varies- JKS offers many cool and unique parts including: Quick Disconnects, Adjustable Bump-Stops, Adjustable Control Arms, Adjustable Coil Spacers, Shackles ETC.
$Varies- Froehlich has quite a few different long arm kits you can buy as well as a rear-coil conversion. He also sells his own custom bumpers and various builder parts.
RUFF-STUFF
http://www.ruffstuffspecialties.com/catalog/
$Varies Ruff Stuff offers many pieces/kits that allow you to build your own 3-link or 4 link long arm kit. They also offer rod ends, shackles, shock brackets, ubolts and just about everything else you need to make your own kit.
TERRAFLEX
http://www.teraflex.biz/shop-by-vehicle/cherokee-xj-84-01
$Varies- Terraflex has a ton of builder parts and a few lifts. Some of the stuff they sell include: Disk Brakes, "Boomerang" Shackles, Long Arms, Drive-Shafts Bushings, Control Arms, Leaf Springs, BumpStops, Blocks, Transfer Case Kits and tons of other stuff.
TNT CUSTOMS
http://www.tntcustoms.com/suspensionupgradeXJ.aspx
$Varies- TNT offers a ton of builder parts/upgrade parts if you want to build your own suspension. This includes: Long Arms, Control Arms, Track bars, Shackles and a bunch of other stuff.
EATON/DETROIT SPRING
http://www.eatondetroitspring.com/
$Varies- Eaton/Detroit Spring offers tons of different custom length/built coil springs/leaf springs and the parts you will need to get them attached. Great if you are going to build your own kit.
Every few months I edit this and repost on the various XJ forums - I'm trying to get a complete list to help people out. (I lost the password to my main account here unfortunately) Please let me know if I am missing anyone or if a link is broken. I update it and repost it. Someplaces it gets stickied and I am allowed to edit it but it has not happened here :) Thanks! (last time I posted it here I was informed of Eaton/Detroit spring)
