gorman
- South Africa
I finished the install of my upgrade suspension over the weekend. In the rear I upgrade my OME spring packs with a couple of custom made extra leafs, while the front got RE4.5" coils and a 1.75" spacer, but with the stock coils spring isolator removed (in retrospect I should have left them in, but I'm sure the rear would settle a bit). The lift I gained was about 5.7" on the left in front and 5" on the right and in the rear I got 6.6" on the left and 6.2" on the right hand side. Why would this be? I've read before that all XJs lean to the right because of the torque effect of the engine and in my case also because of the driver's weight on that side.
I guess the actual question is, do I do something about it, or should I just stop being fussy and leave the measuring tape at home? I could add a 10mm OME packer or the stock coil spring isolator on the right and a 10mm spacer between the leaf and spring pad in the rear to level it out - would this be adviseable? I did install the leaf pack with the highest free camber lenght on the right hand side - the RE coils were both exactly the same length.
