1985xjlaredo
- Kansas City
Yea you should weld those repair panels in especially if you are going up the trans tunnel. You'll notice that with all that Metal gone as in the above pic on this page that it is very flexible and weak. I even welded a couple 1/4" angle piece inside the frame rails to help stiffen them up.
I am thinking of filling up the frame rail with that injection foam insulation now that I have the metal done, to keep out the water and mud cause i couldnt paint under the frame rail once i welded it into place.
