IntrepidXJ
NAXJA Member #647
- Grand Junction, CO
I've got a pair of axles from my old XJ for sale. Looking to get $600 for the pair. They are located in Grand Junction, however, I will be heading up to Salt Lake City from May 21-23 and can bring them with me if you want.
Here's everything that's included:
XJ Dana 44
- Yukon 4.88 Gears
- Powertrax D44 LockRight Locker
- Alloy USA Chromoly Axle Shafts (Spare Stock Shafts)
- Spicer D44 Heavy Duty Cover
- Warn D44 Differential Guard
- Raised Shock Mounts
HP Dana 30
- Yukon 4.88 Gears
- Open Carrier & Spider gears (will need to be reinstalled)
- T&T Customs Truss
- Raised LCA/UCA/Trackbar mounts
- Alloy USA Axle Seals
- Alloy USA Chromoly D30 Outer Stub Axle Shafts
- Yukon 4340 Chromoly D30 Inner Axles
- Spare Stock Shafts
- RuffStuff Diff Cover
- Teraflex High Steer Knuckle
- Crossover Steering (JKS WJ Steering Links and WJ TREs)
- Flipped Tie Rod
Also included:
- T&T Customs Track Bar Bracket
- T&T Customs Track Bar (modified to work with the raised axle mount)
- Custom Trackbar Brace
- JKS Adjustable Lower Control Arms (modified)
- JKS Adjustable Upper Control Arms (modified)
Photos of everything:
XJ Dana 44
- Yukon 4.88 Gears
HP Dana 30
- Yukon 4.88 Gears
- T&T Customs Truss
- Flipped Tie Rod
Also included:
