XJ D44 SW of Chicago
Sure, but you would have to set up the shipper.
I will bring it to whatever carrier you want in the Chicagoland area, (Yellow freight is 1/2 mile from me) as long as it is reasonably close.
Since they are local to you, can you getme a number to Yellowfreight so I can check into shipping? What kind of shape is theD44 in? Straight? Axleshafts OK?
Thanks!
The axle is straight, and the axles are fine, no leaks at any of the seals- it is out of a stock daily driver that hasn't been wheeled so there shouldn't be any twist on the splines.
I'll look up Yellow's #, and send it to you in a PM.
