I'm in Thailand, looking at buying an XJ Cherokee that someone has already swapped in a 2JZ NA engine. As far as I know so far, it was simply bolted up to the AX4 and runs that way - I still need to go see it in person to see what it's like.
The swap was done a couple of years ago, so it's supposedly "sorted out".
I'd like to make it a "performance" vehicle since I can't really buy much of anything here that isn't stupidly expensive (like 80 grand or more for a 6 cylinder Mustang) and thee is no way to import anything good from the US.
The idea would be to remove the 4WD and convert it to 2WD, lower it, probably do C5 Corvette wheels, and manual swap it.
SO, that gets me to my actual question - what is the bell housing face to the gearstick center measurement on an AX15? Apparently on the Supra Trans it's 30.12" and from what I can find on the AX15 it's around 24".
