XJ Cage (Like D and C Extreme)
93JXJ
NAXJA Member #1174
York, SC
XJ Cage from a 93
Survived an on the top flop. Looks like D and C Extreme, made from the same material - 1.5" x .120" wall HREW tube. I had a tire carrier mounted in the back that faced outside. You will need floor plates and will probably want to turn the spare mount (I wasn't running a hatch). It will fit in the back of a full size truck (bring ratchet straps). Cage is together, drag it home, cut it where you want - easier to install then pieces! Located near Clover, SC -about 10 minutes from 49 after Lake Wylie. PM for pics.
$250 OBO
