WTB leaf packs
blondejoncherokee
sacramento
I need some packs to cannibalize to make a second AAL for the MJ. I have a 3" XJ long AAL that is going to go in the thing and shackle I will cut down to 1 1.2" lift shackle, but I thinking the XJ 3" AAL will net only like 1" after it settles- if that. Anyone have any F150 leaves or anything or XJ mains ? . I don't know when ill be going to picknpull next.
Why not just go spring over and use the stock springs?
I just don't want this thing to have 6" of lift and a lot of body roll. Plus the old stock leaves are probably worn out a bit so going over the axle will add some body roll. My buddy has a MJ with SOA and the old stock leaves made it pretty bad on the freeway. we added a 4.5" lift main leaf from an XJ with the eyes cut off and it stiffened it up and he went from like 6" to like 7" of lift. I want to stay at about 4" or less.
I contacted hell creek and their leaves are like 460$ shipped. Rustys leaves are considerably cheaper but I hate rustys. I also could add a second AAL, maybe a shorter one.
I have the old leafs that were in my rough country 4.5" leaf packs when both main leafs broke. They're yours if you want them. I can bring them up to sac whenever I finally bring you your diff cover if you're not tight on time.
Ok sounds good ill take em kevin . Not tight on time. Way too many projects going on.
