WTB - Dana 44 (11") drums
If you're in a really tight pinch, I think d35 parts bolt up. I bought this 44 with d35 brakes from the junkyard. (hope the pic works)
the 35 drums are different so you would have to swap backing plate and everything over I believe? Or at the shoes and all that jazz.
you could also use this time to convert to disc.
The D44 backing plate, shoes, and drums are definitely different.
Yes Jon is correct. The difference being 11" drums vs. 9". Thanks though.
Need by next week, even worn out drums would work for now. (These are for my Daughter's boyfriend=budget)
Idk, tht pic is from the junkyard with 35 brakes on a 44.
it probably has d35 backing plates and wheel cylinders etc.
