WTB D30 DS knuckle
Status
Not open for further replies.
GoSlowGetStuck
Lafayette, IN
I need a driver's side D30 knuckle. Chrysler style (91-01) not the older AMC style.
I just need the bare knuckle. Seems like the kind of thing someone here would have sitting in a box under their workbench.
Thanks in advance!
not in a box, but I do have the worlds rustiest parts axle.
if you get desperate..
I'm pulling my knuckles for wj knuckles...I can pull them now if you need one. I have no idea what they are worth though
I only need the driver's side, I have a hi-steer knuckle on the passenger's side. The hole for the tie rod insert is worn out on mine and I can't get the tie rod tight, easiest solution is new knuckle and drill it out for the insert again.
How about $50 shipped? Since you were probably just going to scrap them anyway :) It looks like it would fit in a medium flat rate box if you are creative.
I am assuming they are less rusty than Nate's... I'm sure when he says something is rusty he means it.
Yes they are in good shape...typical surface rust. I won't be home till Friday, but if that works send me a pm and I can give you my PayPal info
Status
