themangeraaad
- Halifax, MA
Looking for an AX-15. Mine is starting to make noises and I suspect that it is the input bearing but quite frankly idk for sure. If someone has a good AX-15 laying around unused I would rather swap in a trans that I know is good rather than swapping out parts on mine and hoping I fix the problem. Not sure what price range to expect but I am hoping for pretty cheap otherwise I may just throw money at mine and hope I fix the right stuff on the first try.
It would be going into a '93 XJ, not sure if the input shaft or anything changed at all over the years... I read a writeup on doing an external slave swap and it mentioned using 95- clutch parts so maybe the '96+ AX-15 changed a bit? :dunno:
