comanche91
- Sweet Home Alabama
maalox said:Sorry to bring back an old thread, but after reading through a bunch of fan upgrade posts, this one seems to offer the most collective knowledge. I've all but decided on an aftermarket fan(or fans) to replace the mechanical OEM unit, as the Taurus fan, while inexpensive, requires modifications that I don't want to get into. My thoughts on wiring the fan were as follows:
Wire the new fan to run on low speed with keyed 12V. The mechanical fan runs constantly, so I can't see any inherent over-cooling problem(as if you could get an XJ to run that cold, ha!) with running it all the time. Has anyone wired the high speed to come on with the OEM Aux. electric fan? I was thinking a relayed circuit using the power signal going to the OEM fan to turn the main electric fan to high. Thoughts?
The mechanical fan may "spin" all the time, but if the clutch is reading the temps as it's supposed to, there is little or no load on the engine turning the mech. fan when it's cold. I tried to simulate the mechanical fan operation with my replacement electric fan by using a variable speed controller to do the same thing. It only comes on when the temp gauge hits 195*(LO speed) and kicks on HI when the temp hits 210*. Hardly runs at all in the winter. Running it all the time is not a good idea as it wears out the fan quicker and puts unnecessary load on the electrics. And I have my stock aux fan wired separate from the new replacement electric fan as the aux fan doesn't come on until 218*-220*; too high IMHO.
