JNickel101
- Alamogordo, NM
2003-04 WJ Calipers, Knuckles, Brackets, Pads
Unit Bearings - 01 TJ? (for some reason - but I think ones from an 00-01 XJ are the same - you just don't want the ones that were used with "composite rotors")
Rotors - if you get the WJ ones, you'll have to redrill them to 5x4.5". If you go with ones from an 03-ish Explorer Sport Trac, then they're already 5x4.5", but the rotor height is just a hair taller, so you have to space them out from the hub in order for them to be centered in the caliper bracket.
You will also need to re-do your steering - new TREs/heims and a new tie rod/draglink, because on the WJ rotor, it is knuckle-to-knuckle for the tie rod. Drag link is separate and mounts higher. Not sure how else to describe it
