garr
- Nassau County NY
I used the clayton brackets. Work great
Very Nice, I wish I had asked this question last week so I would have them already!
I see Teraflex makes a similar bracket also.
Are you asking if you can install the unit bearing with out the spacer? If so, no you need the spacer to align the pivot point of the knuckle and the u joint. As long as thread is engaged to the end of the hole you should be fine.
01 XJ, 4.5" lift
JKS O/A trackbar mount with RE1615 frame side bracket.
JKS drag link & tie rod with WJ ends Mounted on top (Goferit inserts).https://www.amazon.com/gp/product/B006GJK9NW/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
Question is
What Pitman arm are you guys running, Last time I did this I used an arm (I was told) that came off of a big Wagoneer, a buddy recommends a ZJ pitman for the 1" drop.
Thanks in advance![]()
Thats all an aspect of how you setup your trackbar.
I always use a stock pitman arm.
You don't need a tubing bender. I use those same brake lines on the team naxja car.
Just bolt everything up, and then bend them with your hand. They hold up fine.
Hey Guys
Sorry to kick the dead horse but after reading this thread till my eyes bleed, I’m still unclear on a couple things
1997 Jeep Cherokee country 4.0l automatic with abs brakes d30 front lsd d35 rear 4-5” lift with rubicon express adj tracbar Abs is deleted (abs pump removed)
1. Do I have to relocate the trac bar above the axle tube with my Rub Exp adj trac bar
2. Can I use the OE WJ steering linkage on the xj dana30 (hime joints are illegal on road going vehicles in my area of Canada and i want to be able to pass inspection)
3. Bonus question will my abs axle shaft effect this upgrade
Hey Guys
