Wiring up windows and locks
Krustyballer16
Indiana(IN)
Whats the easiest/best way to wire in 97+ doors in my 90 mj with all the jeep wiring removed?
It's an LS swapped drag truck now and going to be swapping doors some time when I have enough time to cut and weld the strikers in.
But 90% of the jeep wiring has been removed. Basically only stuff left is headlights and radio. Stock fuse panel is still under dash basically just to power that stuff.
Or I also have a set of junk non power doors I could rob the guts from if everything is there to swap em over.
