Wiring of Keyless Entry, Yes I Searched
danny_v_l
Olney, Maryland
Well i got this 88 cherokee as a parts car so i could fix my 87 waggy. After searching around on here i found some helps things about keyless entry systems, i happen to notice the cherokee i bought had the little dome peice, well no exactly the dome, but what i think is the same thing. I yanked it out, got all the wires relays etc... i found the tutioral on how to wire an after market keyless entry to the stock unit, http://www.naxja.org/forum/showthread.php?t=54219&highlight=keyless+entry after reading this, i realized the colors of my wires where not the same. does any one have any info on the unit i took out here are some pics
The housing
The Harness (made By VW)
The chip
Underside of chip
Chip and Harness
Harness has some numbers lableing each wire slot:
1 - black
2 - green
3 - no wire connected
4 - brown
5 - no wire connected
6 - red
Thanks Danny
Black should go to interior lamps or vanity mirror
Pink should go to dome lite fuse
Green shoulkd go to terminal 86 of lock relay
The last one to terminal 86 of unlock relay
