Winterfest Swap Meet
I have a mopar factory hitch.
The one with the 7 pin connector that's sideways and armored.
some light surface rust, nothing significant.
No nut strips
$50
I have a 33" mt spare on a d oval rim. Tire is in good shape and holds air with some goop on the rim as rim is a bit rusty. $50
Are you sure the problem is the rust or the fact it is oval? :laugh:
I have a set of stock tj flairs, with teh corner lights. These are the wide version $50.
I have a rusty's front skid. They are $119 new. Make me an offer.
Great for you guys on 33's or smaller to protect your front end. Has a small notch cut out of it to clear my Tie rod after I moved my front axle forward.
PM with offer or any questions....this could be put on at the camp ground pretty easy with a drill and some 1/2" bolts.
John
I Could use a rear Hatch With Tint/Defrost for a 97+
(silver would be nice but any will do).
Some Shackle reloc. brackets (Ill Contact Brianho)
And for the Spare'Okee I could use stock front tow hook mount and d30 axleshafts
I Have a 36 Tooth Speedo gear Its a short shaft i beleive
(with the electrical plug going to it) If anyone wants it
Working out a deal on some axleshafts so i probably wont need those.
I also have a 12v pressure switch for O.B.A. 85on 105 off. If someone needs one
I'll take the speedo gear, whatcha want for it?
I have a 29 spline 8.25 for sale. Needs shoes, $125 I can borrow a small trailer and bring it to WF with me.
