proskier101
- the vag sander.
if he has to buy new bolts why not just buy grade 8 anyways????
its an upgrade so why not do it?
Urban legend that grade 5 will strech or flex more before breaking I guess.ChrisRFewell said:if he has to buy new bolts why not just buy grade 8 anyways????
Stumpalump said:Urban legend that grade 5 will strech or flex more before breaking I guess.
jeepboy381 said:You also said that the washers are deformed and being pulled into the mounting holes in your bumper, are those holes alot bigger than your mounting bolts?
ChrisRFewell said:the only thing i get about the argument against grade 8 is that when they break they REALLY BREAK! (kinda like steel winch line vs synthetic)
at least thats what i got out of 5-90 first paragraph
but what is the breaking point? how much higher than grade 5? sure people have bent grande 5 and broke grade 5 abd it saved something and caused less stress...but how many acutally broke or bent grade 8?
5-90 said:Without actually looking it up (honestly, I don't feel like digging out that notebook right now...) I seem to recall that the SAE5s are H&T to 150ksi, and the SAE8 to 180ksi. That's 150,000 or 180,000 pounds per square inch for ultimate tensile strength - the elastic limit will be somewhat lower, and the ultimate shear strength is usually considered to be about 75% of that (or 112.5ksi/135ksi.)
Why do I call out per square inch so sharply? Because not many threaded fasteners have a cross-sectional area of exactly one square inch. Typically, you calculate the area using the minor diameter of the threaded portion (unless you're loading in shear, and loading "on the grip" - or unthreaded shank end.) For, say, a 3/8"-16 screw, you're looking at a minor diameter of 5/16", or .3125" (nominal.)
The tensile stress area is then ~.0767 quare inches, so the tensile load that may be applied (as an absolute figure) is ~11,504/13,805 pounds per bolt.
Therefore, multiply by four (four bolts,) and you get 46,016/55,220 pounds of tensile stress, or 34,512/41,415 pounds of shear stress (over all four bolts.) That's assuming the bolts are loaded in "single shear," instead of "double shear" (two shear planes through the shank, instead of just one.)
Most winches aren't even rated that high, using the SAE5 numbers. Yes, you're looking at the preload on the fastener (at what, 35 pound-feet? That means that the fastener is "preloaded" to something like 20% of its ultimate strength, assuming a 3/8"-16 thread. So, that's 36,812/44,176 pounds in tension, or 27,609/33,132 pounds in shear. Still doing well...)
So you see, we're still doing well with fastener strength. Yes, you have more overage using SAE8 instead of SAE5 - but failure modes are more drastic for harder steels - which is why I'm not suggesting them, or just "backing them up" with SAE5 screws. Assuming you're torquing the SAE8 screws in opposite corners to 35 pound-feet, I'd torque the SAE5s to about 30 pound-feet - the SAE8s should still fail first (since they're bearing the brunt of the load,) but the SAE5 bolts will still have room to stretch while the SAE8s are snapping. You can use SAE8 nuts and hardened washers all around, since it's the bolts that are loaded, and the bolts that will fail first.
I know this is a lot - but it's the "simple" version, as I don't have my references to hand and I'm about to head out the door...
Tommy4949 said:Wow thanks a lot. Assuming you are correct in your calculations, if not the exact numbers, I have just learned a great deal in just this one reply. I have always believed you can read more in a short mathematical formula than in a whole page of written words, if you affluent in the language of numbers that is.![]()
Stumpalump said:Hey 5-90, Can you refresh us on whats the best to use as far as fine vs coarse threads go and when to use them?
Never have and never will be a smart ass on the tech forums or when sombody genuinly needs help. I kinda had the basics but thought this would be a perfect place for you to explain it best and expand any general knowlege we had. So if I want threads in a piece of square 3/16 mild steel tube to bolt a skid plate to I should use fine threads. Thanks5-90 said:I could assume you're being a smartass, but there are some who would benefit...
Stumpalump said:Never have and never will be a smart ass on the tech forums or when sombody genuinly needs help. I kinda had the basics but thought this would be a perfect place for you to explain it best and expand any general knowlege we had. So if I want threads in a piece of square 3/16 mild steel tube to bolt a skid plate to I should use fine threads. Thanks
