Im about to take advantage of 4wds 20% off and want to make sure I order the correct parts.
I made a bastard pack with Dakota leafs for about 4" of lift. Will these ubolts work or will they be to short?
http://www.4wd.com/productdetails.aspx?partID=15331
http://www.4wd.com/productdetails.aspx?partID=7782
Not sure where to get leaf spring clamps and how to determine the size I need other then 2" wide.
Ill be straightening out the front brake lines.
Trac bar will remain as is since Im using Rustys HD 3" lift springs up front.
I have stock JK shocks (not rubicon) for shocks and front BPE's.
When my rear shock bolts break what size do I replace them with?
What size bolts do I need and how many for the OEM front and rear tow hook brackets?
Anything else?
Rear brake line for '90-'95 YJPart Number: EXP4WD602P
* 1990-01 XJ Cherokee with Chrysler 8.25 rear axle
* Factory style replacement
* Set of 4
For use with Chrysler 8.25 rear axle. Set of 4 U-bolts.
Ill be using grade 8 hex heads for center pins.Part Number: OAI16733.05
* 1990-95 YJ Wrangler
* Pre-assembled with all fittings
Anything else?
