Dino,
I have a very similar setup to yourself and I'm picking it up from the engine shop tomorrow afternoon for a weekend install.
I only have experience replacing simple stuff like bearings so I figured I'd leave the assembly to a good local shop.
My base engine was a 1989 4.0L bored out .030"
1987 4.2 crank..short snout version with matching rods.
Sealed power 677CP pistons
Comp Cams 68-231-4 with matching lifters
Mopar Performance valve springs, retainers, and keepers.
The head was machined .010" with a mild port and polish to help increase volume.
HO fuel injectors at 22lb/hr with fuel pressure bumped to 43 psi
MAP adjuster probably set up around 6 volts
I'll be sticking with the non-HO computer and injection system so hopefully the EGR and knock sensors will allow me to run 87 octane gas.
With the head and intake being somewhat more restrictive on the older NON-HO engines my calcs only show about 22.5 lb/hr fuel injectors being required so hopefully the HO injectors will flow enough to prevent a lean condition at WOT.
I'll keep you posted on the test drive next week
