which clutch should i get or can i reuse the one i have
rav
Albany, NY
Hi Guys;
I am collecting all the parts to swap my peugeot to the AX-15, i have a 1 year old centerforce clutch on the peugeot, will i need a new clutch for the 96, AX-15 thats going into its place or can i reuse the one i have. Also if i have to buy a new clutch which one would you recommend, the valeo one is much cheaper then the centerforce, any info or suggestions on the swap will be appreciated.
Thanks;
Ravi
I'm going to guess that you can probably use the same clutch. If anything, the AX-15 may have a different spline count on the input shaft. If that's the case, you don't need an entire new clutch, you just need to buy a clutch disc for the year XJ the "new" tranny came from (96?), and run that with the same pressure plate.
