<<where?>>
JVRacer04
Houston TX
so i found my problem why my fuel pump isnt running so i temp. fixed the problem by running a fused line to my fuel pump relay circuit... but now im still even blowing this fuse. ill track down the short but in the meantime...
where is the fuse for the fuel pump? (its an 89...renix) and where does it get its constant power?
heres a photo of what i did and the fuse i need help finding
Did you check with all the other fuses or under the hood?
Most all of the fusible links are in a bundle bolted to the starter motor relay next to the battery. *In the six cylinder*.
