Found one in a u-pull in Orlando. $75 if you pull it your self. Double that atleast if they pull it for you. They can be found. I had to check all of the xj there and found one with a 44. I think its still there. T.
I am running a d44 from a 96 isuzu rodeo, you really can't beat it. It is a slight bit narrow but all it takes is 1/4 in spacers. Plus it uses the larger carrier bearings, not the smaller jeep d44 bearings. Plus the axle shafts have alot less taper length and it will have disk brakes. I am running mine with 4.56s and lincoln locked and it has always gotten home.
Chadc
i picked up my 89 "limited' on ebay for 600.00.........with a stock D44..... was like a pot of gold..... the MJ had the D44 available for a longer period of time but there were less of them produced.... if you get an MJ axle remember you will need to do a SOA perch change..... i have heard conflicting info as to how long it was available in the XJ, but 87 is the best shot...
TAPCO International?
I think that was the name of the place some folks were able to buy new ones from a couple of years ago. Seems like they were in the 4-5 hundred dollar range complete, drum to drum. I haven't heard anything since then but it may be worth checking into. TC
