Yeah if you plan to wheel your jeep, you're going to hit your bumpers and rockers if you're not careful.
Been there done that on my 3 other XJsThat's why rock rails were one of the first pieces of armor I built for this one.
I took the driver's door panel off and greased the mechanisms for the door lock. Didn't change anything, so I gave up on that. Super productive weekend.
Www.teamcherokee.comHey Devildog, if you replaced the seals the window slides in where did you find them? I looked a while back and wasn’t able to find them.
Couple of hours. Took about 2 to do the driver's side and about 1 to do the passenger side. Most of that time on the driver's side was figuring out what angle to get he windows out and what order everything needed to come out and go back in. Passenger side went much smoother.I wouldn’t mind paying $350 to have new seals. How long did it take to take your doors apart and how difficult was it?
I replaced the Bilstein 5150's on the front of my XJ with some 5165's. The ride is much smoother, less jarring when it hit a rut and far less body roll. The bad? The 5165 have eye top and bottom. I had to use some adopters. That reduced my up travel by 1.5" +/- which is bad. I need to add another 1" of bump stop. Maybe I could use some shorter adopters. Some of those pieces that came on the XJ rear anti roll bar come to mind. I have to research the availability.
Previously, there were 4" up travel between the bump stop and the axle pad and 4.5" on the shock. The new shocks have 3.5" of up travel left.
I've been thinking of going with the 5165's or 7100's myself. Though I really don't want to reduce uptravel. Which adapters did you use?
From 4 wheel parts, they are EXP 690001
