What was done to YOUR rig(XJ/MJ) today MECHANICALY????
Re: What was done to YOUR rig today?
i rolled mine last night http://viewmorepics.myspace.com/index.cfm?fuseaction=user.editAlbumPhoto&albumID=1519024&imageID=21981141 it slid sideways and it rolled. any one have a xj for cheap?
index.cfm
hahah no freaking way! btw that link doesnt work
what does the front look like. You could back-half it......then replace the rest of the damaged top from another XJ, not really that hard just time consuming....
You don't need another one. That one looks fine to me.....
I would just bang out(or cut off) what you can, build a cage, and call it a "trail rig". At least you don't have anything to worry about body damage. LOL
So... does this mean you will have an XJ to part out?
Got an alignment then washed it. Changed a corner marker bulb or whatever its called. Then measured to see how much lift its actually at. Barely over 3" in back, and barely under 2" for the front. Need to order some 3" springs for the front when I get a job/money.
Topped off the radiator. Figured out my LCA bolt needs tightened. Installed a front hook, put some tail lights on the roof rack for flat towing so now I'm all set up for a trip somewhere
Rides of March sounds good to me.
Inspected inside of cat. converter, did a compression check, installed NGK plugs. Had a pending code of misfire on #2. Still have the annoying buck at 1200rpm when I come to a stop. Haven't driven on the expressway yet. Maybe I'll hold off for a day and take the bus to work in the morning!
Hope to install the hitch sometime this week.
Bought a 3rd front drive shaft for a spare and few other goodies.
My shit got impounded. :(
Short lived glory.
Smart... real smart. You call some of us "old timers" but with age comes wisdom. Sometimes.
Did you do something to give the offroad community a bad name?
