- Houston, Tx
Got up to take mine to cars and coffee
Didn't start
Guess I'll be putting in my new battery cables while I charge the battery
Didn't start
Those 35's will become one of your better investments off road... not so much on the pavement![]()
I must have spent 16 hours the last week debugging my Renix miss fire and stumbling issue.
The more time I spend on it, the worse it gets.
I just impulse bought 35s
What'd you get?
Wish me luck, down to changing the seemingly good (in all tests so far) Renix CPS, to see if that solves the running like a POS, barley runs now problem on my Wagoneer XJ DD. After that, it is has to be wiring:gag:, the ECU or the engine:gag:. The Snap on MT-2500 was telling me all along the ECU and sensors and engine were fine, but that it was just wanting to run a bit rich (STFT was lower than OEM specs).
I've run every test know to Man and Naxja and Renix Gurus.
hasta I sure hope its the CPS.
Happy 4th, and may the Fourth be with you all!!!! :cheers:
Well the Dark side of the Fourth won Tuesday night and ate one of my CPS shoulder bolts, somewhere in the bell housing.
Getting old sucks.!!!1
I am working on my master Jedi stealth plan for helping it escape the bell housing it is now jailed in. The dark side will not win this war!!!
It's ALIVE!!!!!:laugh3:
My Wagoneer is running again. Dizzy sheer pin died. New dizzy and indexing (cutting off the ears ) and using the www.cruizer54 indexing procedure to fix the factory Dizzy/Cam shaft OEM errors got it running and no more back firing no matter how hard I try from 1500 to 4500 rpm. Runs great from 1500 to 4500 rpm.
Now to solve the new problem, a rough idle. :rattle:
