What was done to YOUR rig(XJ/MJ) today MECHANICALY????
major props....very clean restoration. Build thread or plans?
Thanks! To be honest, I'm taking it much further than I originally intended. I started a build thread on another forum, but I haven't kept up with it. I'll start one here later today. My plan constantly changes, But it's going to be mostly stock. Just renewing everything I can, and going with a 5.5" spring over axle lift for now.
OK drove my Jeep on the highway yesterday and used Cruise for the first time in awhile. "Seems" like the CRUISE kicked out whn climbing a hill. Would not come back on. Had to stop, turn off engine and restart to use again. Later it went off as designed when I tapped brake. Did not come on again until restart.
What may I check? Is it a computer glitch?
I checked for vacuum leaks the best I could. Saw a post that the switch sometimes just wears out... anybody know ow I could test that?
Dropped my tires off, hopefully just need to be re mounted
I checked for vacuum leaks the best I could. Saw a post that the switch sometimes just wears out... anybody know how I could test that?
Ohm meter if it is dual electric and vacuum test for a leak. It is mechanical!!!
Here is the most complete write up on the old XJ cruise control I have ever seen!!!
http://jeep-manual.ru/index.php?page=78
and Cruiser54 has a write up at www.cruiser54.com as I recall
Jeep vehicles use an electro-mechanical servo system. The system consists of a control module, speed sensor, servo, control switch assembly, vacuum storage canister, check valve and release system. Release system consists of a mechanical vacuum vent valve and brake and clutch (M/T) release switches.
Cruise control switch is an integral part of turn signal switch lever and consists of 2 separate switches. First is an "ON-OFF" and "RESUME" slide switch located on flat of directional switch lever.
Second is "SET/COAST" push button switch located at end of directional switch lever. To engage system, move slide switch to "ON" position and accelerate to desired speed. Depress and release "SET/COAST" button on end of switch lever. System will now maintain selected speed.
System will automatically disengage when brake or clutch pedal is depressed. It can be re-engaged to previously selected speed by accelerating to 30 MPH and moving slide switch to "RESUME" position, then releasing switch.
NOTE: When slide switch is moved to "OFF" position, pre-set speed of "RESUME" function is canceled from memory and must be reset when system is reactivated.
Higher speed can be set by pressing on accelerator pedal until new speed is reached and then pushing "SET/COAST" button. Lower speed can be obtained by lightly depressing brake pedal, allowing the vehicle to slow to desired speed and then depressing and releasing "SET/COAST" button.
CONTROL MODULE
Control module receives input voltage representing vehicle speed from speed sensor, which is driven by the speedometer cable. Control module has a low speed circuit that prevents operation at speeds below 30 MPH. See Fig. 1.
SERVO
Servo is controlled by control module and uses manifold vacuum to control throttle. Bead-link chain connects servo cable to throttle linkage. See Fig. 1.
CONTROL SWITCH
Control switch assembly is an integral part of turn signal switch lever. See Fig. 1.
RELEASE SYSTEM
Release system deactivates cruise control system when brake or clutch pedal is depressed. Either servo vent valve or mechanical vacuum vent switch admits atmospheric pressure into servo when brake pedal is depressed.
TROUBLE SHOOTING
NOTE: Vehicles with computerized engine controls, should be tested for stored computer codes. Codes and related problems must be repaired prior to cruise control diagnosis and repair. For additional information, see COMPUTERIZED ENGINE CONTROLS section.
SYSTEM WILL NOT ENGAGE
Restricted vacuum hose or no vacuum. Control switch or control module defective. Speed sensor defective. Clutch or brake light switch defective or misadjusted. Brake light switch wire disconnected. Open circuit between brake light switch and brake lights.
RESUME FEATURE INOPERATIVE
Defective servo ground connection. Defective control switch. ACCELERATE FUNCTION INOPERATIVE
Accelerate circuit in control module inoperative. Defective control switch.
SYSTEM RE-ENGAGES WHEN BRAKE PEDAL IS RELEASED
Defective control module. Mechanical vent valve not opening. Kink in mechanical vent valve hose. Brake light switch defective.
CARBURETOR THROTTLE DOES NOT RETURN TO IDLE POSITION
Improper linkage adjustment. ROAD SPEED CHANGES 2 MPH OR MORE WHEN SETTING SPEED
Centering adjustment wrong. Servo link misadjusted.
ENGINE ACCELERATES WHEN STARTED
Improper servo chain adjustment. Vacuum hose connections reversed at servo. Defective servo.
SYSTEM DISENGAGES ON LEVEL ROAD WITHOUT APPLYING BRAKES
Loose wire connection. Loose vacuum hose connection. Servo linkage broken. Defective brake light switch.
ERRATIC OPERATION
Reverse polarity of system wiring. Defective servo. Defective control module.
VEHICLE CONTINUES TO ACCELERATE WHEN "SET" BUTTON IS RELEASED
Servo or control module defective. SYSTEM ENGAGES BUT SLOWLY LOSES SET SPEED
Air leak at connections or in vacuum hoses. Air leak on vent valve on brake pedal.
ADJUSTMENTS
CONTROL MODULE ADJUSTMENT
NOTE: Control module adjustments are preset by manufacturer. If
other components in system appear to be functioning properly
and cruise control remains inoperative, perform following adjustments to determine if control module is functional.
1) Remove control module attaching screws or tie straps and
move control module downward for adjustment access. Turn centering
adjustment screw to 10 o’clock position. Turn low speed adjustment
screw to 10 o’clock position. Turn sensitivity adjustment screw fully
clockwise.
CAUTION: Adjustment potentiometers are extremely delicate. Carefully insert screwdriver and do not push or turn screws excessively hard. Maximum movement is 3/4 turn.
  • Adjustments are not precisely correct for vehicle, but are
    acceptable to determine if control module is functioning. Perform
    precise adjustments by road testing vehicle on level road. If
    adjustments have no effect on cruise control, replace control module.
  • If actual engagement speed is 2 MPH or more above selected
    speed, stop vehicle and turn centering screw 1/16 of a turn
    counterclockwise. Recheck engagement speed and adjust as necessary.
  • If engagement speed is 2 MPH or more below selected speed,
    turn centering screw 1/16 of a turn clockwise. Recheck engagement
VACUUM VENT VALVE
Depress brake or clutch pedal and hold in depressed position. Move vacuum vent valve toward bracket on pedal as far as possible. Release brake or clutch pedal.
TESTING
PRELIMINARY INSPECTION
Ensure cruise control wire harness is properly connected to
control module before starting diagnosis or repair procedure, as this connection is disturbed when Cruise Command System Tester (AM PC-1-R) is used. Poor connection at this point may be improperly diagnosed as control module malfunction.
Brake light and clutch switches should be properly adjusted. Ensure that all vacuum lines are correctly routed and tightly connected.
CRUISE COMMAND SYSTEM TESTS
Testing is performed with Cruise Command System Tester (AM PC-1-R). Remove wire harness connector from control module. Connect tester to wire harness connector. Perform tests as part of service diagnosis to determine cause and correction of system malfunction. Various tester lights are associated with specific components, circuits, etc.
CONTROL SWITCH CONTINUITY
Wrangler
NOTE: Voltage checks should show battery voltage. If resistance readings are incorrect, check circuit for an open or a short. Cruise control module terminal No. 1 grounds through connector at engine block.
Light No. 1 "OFF" (Set Switch)
With control switch in "ON" position, check for battery voltage between HAZ/STOP and in-line fuse, terminal No. 14 and ground terminal No. 1
Light No. 2 "OFF" (Control Switch & Speed Sensor) With control switch in "ON" position, check for battery voltage between HAZ/STOP and in-line fuse, terminal No. 5 and ground terminal No. 1. With ignition switch in "OFF" position, check resistance between terminals No. 2 and No. 3. Resistance should be 15-50 ohms.
Light No. 3 "OFF" (Brake Light Ground)
With ignition switch in "ON" position, install jumper wire between terminals No. 7 and No. 13. If brake lights do not turn on, check fuses and brake light switch connections.
Light No. 4 "OFF" (Throttle Position Feedback Sensor) With ignition switch in "ON" position, check for battery
voltage between gauge fuses at terminals No. 7 and No. 1.
between terminals No. 2 and No. 11. Resistance should be 2400-4000
ohms. At idle resistance should be 2800-4300 ohms and at wide open
throttle resistance should be 4000 ohms.
Light No. 5 "OFF" (Resume/Accel/Vent Valve) With control switch in "RESUME/ACCEL" position, check for battery voltage between HAZ/STOP and in-line fuse, terminal No. 10 and ground terminal No. 1. With ignition switch in "OFF" position, check resistance between terminals No. 6 and No. 12. Resistance should be 30-50 ohms. Resistance between terminals No. 6 and ground, and terminal No. 12 and ground should be infinite (open).
Light No. 6 "OFF" (Resume/Accel/Charge Valve) With control switch in "RESUME/ACCEL" position, check for battery voltage between HAZ/STOP and in-line fuse, terminal No. 10 and ground terminal No. 1. With ignition switch in "OFF" position, check resistance between terminals No. 4 and No. 12. Resistance should be
30-50 ohms. Resistance between terminals No. 4 and ground, and terminal No. 12 and ground should be infinite (open).
WRANGLER CRUISE CONTROL TESTING
Conditions Lights "ON"
Control Switch "ON" & Set Switch Depressed No. 1
Control Switch "ON" No. 2
Ignition "ON" & Brake or Clutch Pedal Depressed No. 3 & No. 4
Cruise Control & Resume/Accel "ON" No. 5 & No. 6
Cruise & Resume/Accel "ON" & Engine Running (1) No. 5 & No. 6
(1) - Servo will pull throttle wide open. Keep RPM at a safe level by releasing cruise control switch.
Except Wrangler
Use 12-volt test light to test control switch continuity. Connect test light to wires as indicated in CONTROL SWITCH CONTINUITY TEST CHART. See Figs. 3 or 4.
That is just part of the write up on that site!!!
I may just finally try to get mine going for the first time. Never really tried to fix mine, always seemed very low on the priorities
I'm starting to get serious about working on rust and paint pre and painting my rigs. Not looking forward to it. :shiver:
Just saw this and have not read all the details but if cruise control stopped working while climbing a hill then it sounds like a vacuum leak on the cruise control side of the vacuum canister. Also, it could be a missing/non-working check valve where the vacuum line enters the dash. Not sure if the cruise is on that circuit or not but I think it is. Do the blower vents switch to defrost when you climb a hill or accelerate?
Thanks Mike but mine is a 2000 and controls on steering wheel not Signal arm. I will look closer at Vacuum leaks. Where is that check valve located I need to check that too.
FYI since I bought the Jeep I have never had the light on the dash when cruise engaged although it has worked fine for the last couple years.
Thanks for all the ideas... pls keep them coming if you think of any more
The check valve is under the hood, near the fire wall heater hose and AC connections, at least on the older XJs. Much of the CC stuff may be the same on a 2000, if not it will be common Chrysler car junk LOL.
Verdict: bent one wheel, had the bead gunked up on the other
Holds air but might not with weight on it. Anyone have a wheel repair guy?
Went to junkyard
No flares
There is a shop at 2701 So Shaver in Pasadena that does aluminum rim welding repair. Been there for over 10 years.
Azteca's Rims & Tires  
Tire shop in Pasadena, Texas
Address: 2701 Shaver St, Pasadena, TX 77502
Phone: (832) 883-1251
Hours: Closed today
He has a facebook page. Or google it...
If you use him, call me and lets meet up, I am just around the corner
And the ac is back to not working
That reminds me, I need to find out why my AC runs for a good while, then cuts out (too cold) and will not activate the clutch later when it gets hot again unless I goose the engine to about 3000 rpm. Had that problem with the 89 ( may she RIP) and my 87 waggy for years. I think I am going to try and debug that this month. Pretty sure it is/was not a ground issue. The clutch and AC works fine when I first start the jeep.
I guess it could be something in the dash controls or the Evaporator thermostat going bad???
But why does the clutch always engage when I rev it to 3000-3500 rpm when it suddenly decides it want the rest of the day's trip off LOL. There must be a connection. The air gap on the clutch comes to mind, or voltage to the clutch, but why does it work for a good while, then go south after a 30 minute drive in hot weather? And why would a rappid rpm run up fix it for while?
