Build thread?
No. It was an 85 gas 4 banger that had the engine replaced with a nissan diesel 4 banger, an SD-22 before I bought it used in a wholesale dealer lot for $950 cash in 2002 when no one wanted to buy anything (not long after 9/11). The swap was rushed and needed a lot of work to get it usable as a daily driver. I had no idea at the time what engine had been dropped in it. It was a black box for a year or so. It was my first jeep too. (had driven my ex-girlfriends 96 jeep and fell in love with jeeps). So I dug for answers as to what I had. Had to figure out what parts were jeep and what parts were something else. Finally got lucky one day and identified the engine as the 1981 pick up truck diesel engine, the SD-22 and found a great site on the nissan engines. Redid the power steering, redid the entire A/C, worked on the rats nest of Jeep wiring issues, rebuilt the 5 speed Nissan transmission (that was a chore). Funny story I drove it for 6 months before I discovered it had a fifth gear, LOL. The engine is only about 61-63 HP but gets 34 MPG in the city. Had to diagnos the balck and white smoke puking issue after about a yearm that look like the end of the project, till Al (the Nissan site) and his friend steered me to a $25 leather diaphragm (now no longer available
) that was modulating the Bosch fuel injector pump that was dry rotted that fixed the smoke and puck problem. The fuel injector pumps were hard to find and cost more than the jeep. And I was not fond of the idea of rebuilding a diesel engine at the time so that fix was a huge deal for me. But it took 6 months to find the real problem. Since then I have made many repairs and mods.
But sorry no build thread or history thread. I did make the new engine mounts I made out of steel belted tire tread using used junk tires. Last major thing was I let what I thought was a good mechanic try to solve a hard to push clutch problem and he pulled the entire dash and made a huge mess to get the clutch-brake peddle assy under the dash. Another friend has been helping me get it back together while adding wiring and removing obsolete wiring from the firewall, engine bay to cab. I needed help because of my extreme rheumatoid arthritis limits my flexibility and ability to use tools. The clutch problem is due to my RA not due to the clutch. I need a way to make the clutch easier to push for my weak leg and foot. It would kill me hitting 5 o'clock traffic for an hour with my weak legs, knees etc. I am thinking of adding a small air bubble to it to make the peddle soft and mush but still working. Or I may use my chemical engineering experience and try adding a custom adjustable pressure relief valve to the line to lower the peak pressure
It had a softer peddle, that still worked before I fixed it 4 years ago LOL, with a new line, new MC and SS and some hard core bleeding and repairs to the peddle hardware that had a failing weld. Did more work on this beast than any other in 43 years. Had to bypass 80% of the oem fuse box years ago.
Replacing the bad gauge set light bulbs and cleaning the circuit board style contacts today
