WHat trail levels do you want to run???
Andy in Pa.
NAXJA Member #180
Downingtown, Pa.
The trail levels we typically have are Green, Blue, Black, and a Red group, otherwaise referred to as the "Stupids" group.
This is the minimum requirement for the trail levels:
Greens:
stock Jeep
Blues:
3" and 31" tires, one locker recommended
Blacks:
4" and 33" tires, two lockers/gears recommended, possible damage to Jeep(dents, broken parts), winch recommended
Reds:
6" and 35" tires, two lockers/gears/spares, possible damage to Jeep (dents, broken parts), winch highly recommended
There are exceptions to these guidelines, but this is a good place to start.
So post up what level you would like to run...
A.
I'm probably going to plan on Blacks and *maybe* some "lower level" Reds if that's a valid term... I refuse to let my new Jeep end up like my old Jeep. It needs a good cage before a good thrashing. Plus, I need to drive it 400 miles home :laugh3:
I would suggest waiting to see how many people we have for each, and perhaps set up a blue/black group and a black/red group if needed, because there are always us inbetweenie peoples.
edit: Ill wanna run blue/black
Yep... like I said, these are guidelines... As you know, quite often we have Blue/Black groups and Black/Red groups...
A.
You forgot a group, Andy.
Greens
Blues
Blacks
Reds
Sit in the parking lot for three days and ride a flatbed home.
Sign me up for the last group!
If I'm not needed to lead a greenie group, I'd like to hit some blues and maybe flirt with a black or two (you know how I tend to roll).
should we make a master list?
I'm good with blue or green/blue. I'm running open diffs.
