Ben824
- Woodstock, GA
I recently bumped my tire size up to 33x12.50r15 from 31s with the help of some bushwacker flares. I have RE 3.5" coils up front and RE 3.5" full leafs out back with RE monotubes all around. I also have JKS LCAs and trac bar. Now I have since noticed that my Jeep has a slight rake to it which I never really noticed before. The tires do rub some up front when at turning at full lock and I worried when flexing it will rub pretty good so I was thinking of throwing some spacers up front to level it out and stop the tires from rubbing. So my question is what size spacer do you think I should go with? 3/4", 1.5", 1.75", 2"? My only concern is if I go much bigger than the 3/4" spacer if that will be too much for my JKS trac bar because they make 2 different sizes, one that is rated for 0"-3.5" lifts and one for 4"-6.5" lifts.
Here is a picture of how the Jeep sits now:
