What Sensor Am I?
AIbandit
Chico, CA
What are these 3 sensors?
Yes Ive cleaned the garage since then :)
Lol thanks :moon: :D
The one on the left is the temp switch,the one on the right is your oil pressure sensor. You guys are having to much fun,looks like nascar is still in rain delay.
knock sensor on bottom, temp sensor on top
oil pressure sender
Thanks Ehall
Clever I take it in your opinion everyone that builds there own engine is a redneck? or is it the 7000$ quad in the background or is it the cherry picker's box that I just bought for this swap. Maybe my compressors box? Or any of the other boxes from just moving in. My appologies I don't quite meet your standards nor does my garbage mans small recycling limit. I'm sure with the name "PiknPul" you must be a higher class then me.
Maybe you should know someone before you talk shit newb.
ohhhh noesssss I knew I should of put a smiley face...
Doh! you got me! I work for a range :D
nope-- it was the Fram filter....:D
(notice the smiley)
So if i tear the wires off my KNOCK sensor would i notice more knocking? I must look into this, then i could run 87 ...
Thank you guys for this tread..You to MpSlayer:wave:
I'm not sure he intended the comment as an insult. Maybe Nascar really is delayed, he's bored, and thinking an engine install sounds like fun. Or did I miss something?
