magimerlin
- Flatonia, Tx
ok crack haed again to far it was not jay welder so get off my ass secondly kurk ur welds dont look any better u just grinded the crap out of ur. plus that welder fis loike jay's vits not gas and it is a mig. note not gas migs r 4 lite doty work and not for good stranth. when u do not use gas there is no shild to keep the weld cool. so the wheld gets to hot to fast and then cools down to fast. and not to michen there r to difren tipes of metal one bing stanless and the other bing just what some call just regler stil.
so why don't some of yal go read a book or take a class or some thing.
Ok
1st off enough with the name calling its pissing me off. You do not want that here. Kurt knows what I am talking about. I will go past to far.
2nd learn to take criticism, and learn fast. I know children that take it better than you do.
3rd. Kurt grinds down the weld so it is flat. His welds have plenty of penetration, after the welds are ground down it is still welded solid. My welder is a mig welder set up properly to not use gas at the moment. So there will be slag, get over it. It will have to be ground down more then a welder using gas.
4th. migs(gas) are for smaller jobs, and non-gas are for larger/heavier jobs. And larger wire for thicker metal. They do not recommend using gas for thick metal. Its even on all the welders recommendations on the back side of the access door for the wire.
5th. Yes my welder can be set up as a mig(gas mix), but it is not set up that way at the moment it is set up with .035 innershield wire. So my welder is set up properly for thicker metal.
6th. Unless I missed something here, which I may have. were do you think you have stainless metal on your jeep or on the bumper. All I saw there was regular steel, nothing more nothing less.
7th. the gas is not to cool anything. It is to give a cleaner weld. It helps keep out the impurities in the weld, for better corrosion control.
ok go ahead and try to prove me wrong if you wish but my info comes directly from Lincoln and my I-Car training.
ok I'm off my soap box till next time. :cheers::cheers:
