Lawn Cher'
- Westampton, NJ
BrettM said:leave your TV cable adjusted properly.
What should I do if I have satellite TV?
I adjust my assmouth daily.Lawn Cher' said:What should I do if I have satellite TV?
Lou said:I adjust my assmouth daily.
fire325 said:Learn somethin' new everyday. I have adjusted mine 2 different ways. 1) by opening the throttle cable all the way, and let go. 2) by using the gas pedal to the floor. I get a different setting with both methods. #1 method, it shifts harder. #2 method, it shifts softer. Which method is the best?
Oh, and thanks for letting me know the real truth to that. I appreciate it :wave:
No, and yes.Lawn Cher' said:Are you saying you don't appreciate my insightful commentary, or did you just mis-type azimuth?
2) by using <pressing> the gas pedal to the floor.fire325 said:Which method is the best?
sjx40250 said:Out of curiosity, is the TCU the same for both 90 and 91? Could you add the comfort switch to new vehicles?
Littlewhitexj said:can someone tell me what exactly this switch does?
http://www.midwestoffroad.com/modul...serpics/10011/normal_connies camera 006~0.jpg
Beats the hell out of me how it would be in sand, the only time I use the power version (have an 89 as well) is going up steeper canyon roads, kicks in like an overdrive, which matches what the guys were saying about shift points.jbt114 said:I found this post many pages ago and was hoping to revive it because I'm still not sure which is the best way to use this accessory. Should I be using Comfort or Power? I have an 89 XJ that I use to surf fish the shores of Long Island.
Thanks in advance,
Chris
Thanks in advance,
Chris
Towheelie said:I was told it also keeps the auto tranny from shifing into overdrive (?) Never really checked to see if it does or not.
