What do you need to get done for ROM?
Crusher16
RRC President
Richardson, TX
Jeep gets regeared next weekend. Got a double shear track bar upgrade to put on. Might try and tackle that this upcoming week.
Who is doing what to prepare for another fun ROM?
I'm replacing my broken center pin in my leaf :) Not going to use the leafpacks I bought from the guy in Dallas. So they are available ;) I hope to replace the coils before then too. Will put in new front bump stops and hockey pucks while I'm at it.
Need to figure out why I'm having a problem stalling at idle :(
lets see, i need to get my new gas tank assembly on, 4x4 swap, rebuild my d30/8.25 combo, slightly more lift, make a rear driveshaft, make a rear recover point, figure out why my CB set up doesnt work anymore, install a muffler, and finally get a radio in it.
clock is ticking.....
Finish installing new trackbar and mount.
Change out uca bolt with custom plastic bottle cap nut.
Change out some tre's.
Install new rear bumpstops and possibly fronts if they work with my softballs.
Fix blinker issue and headlights.
Maybe install new clockspring so I have cruise control for the drive.
Swap rear leafs if I'm feeling froggy.
hopefully get my rear tire carrier in from JCR back in black sale, get it painted and throw it on.
Damn...just remembered: still need to figure out ebrakes from the zj swap too.
Should have posted this sooner. I got the shipping notification about an hour after this.
Jeep is geared.
Next up:
Fix tcase leak
Have rear driveshaft rebuilt
Install double shear track bar upgrade
Maybe Durango box upgrade
fuel system done!
still have axle swap
4x4 swap
sye install
steering to be fabrbicated
rear recovery point (bumper) to be fabricated
cooling system to be gone over
CB radio fiddled with
driveshafts made
a secure gas tank mount fabricated
some proper coils and shocks found/installed
and if i have time sliders fabricated.
wait did my list grow?
Dang....did I forget to mention the leaky ps reservoir?
Still haven't done a damn thing....:wow:
Jeep is geared.
Next up:
Fix tcase leak
Adding:
Have LCA skids welded on
Install new rear pinion yoke
At least he has some good help with this one ...
