NW99XJ
- Gresham, Or.
Needs some mechanical isolation on the mounting AND there's probably a resonant frequency vibration issue at the mounting. Anything un/improperly attached?
Was looking a the buckets last night, everything seems to be solid.
Spring is there.
The bucket is sitting in the groove of both adjustment screws.
The metal retaining surround thingy, is nice and tight.
The connector plug fits securely on the back of the lamps.
_i'm out of ideas.... In the last year i've had to swap out bulbs in one side or the other at least 4 times...
The one idea I have is: that because the housings are plastic and not glass, there's less heat sinking, and the ambient temperature surrounding the bulb is higher than what it should be, thus diminishing the life span of the bulb.
I AM installing them right, -licking then rubbing the bulb in my armpit before dipping it in gear oil as i secure it in the housing..... (i'm kidding of course)
