Sneaky
- Kelso, Washington
Re: Re: What did you do to your XJ today
You can do this all at the relay in the fuse box under the hood. Take and t-tap or scotchlock a wire from your switch to terminal 85 wire under it in the fuse box housing. Then ground your switch input. This will ground that relay terminal when you activate you switch to kick the fan just like the sensor does.
For constant power cut the wire for terminal 86 as it is switched 12 volts and tap it into the hot wire from the fuse that powers the relay. Be sure to isolate the wire in the harness with a connector or tape so it doesn't short out. This will allow for the fan to run when hot and the Jeep is turned off.
any more info on what you have to do to make the fan powered on all the time? I tried the same, and spliced right into the wire before the connector to the fan, but it doesn't seem to work via switch, just comes on when it used to come on...![]()
