What are you doing to your rig - the continuing saga
Pushed pins/poor contact in the connectors. Don't know- I'll check.
NSS needs to be replaced (I know you've already cleaned it, but it might just be beyond repair at this point) Its functioning normal as far as I can tell.
Kickdown cable properly adjusted? Seems to be.
How's the tranny fluid look/smell? Not bad/ not burnt.
Is it a constant problem or is it related to engine temp? Used to be temp related (occurred when it reached operating temp) but now is constant.
:cool:
CEL has been off since I replaced the VSS and no codes are showing up.Speedo continues to constantly bounce from peg to peg.
Note: CEL is currently on due to the TCU being unplugged.
I'm sure somebody will have an empty seat you can sit in. Hell, Troy will have 3 most likely if he is willing to share.
YAY Boy. These arms are going to be beast
Workin on a few things before the weekend! Don't think ill have ball joints installed though.
HID kit will be here tomorrow so I can finally put my front end back together. Put an Alpine head unit in and will have some used BOR 4" leafs on the way!
