RideFree416
- Littleton, Colorado
Damn. cant wait to see mine! My pinion bearing is probably equal to or worse 0_o
Actually pretty comparable to the price of frame stiffeners and nice rock sliders, and these are both in one package. When you see how these are built in person and how much work hooligan puts into these you will see they are worth the price imo
Trying to track down a damn rim on the cheap, and considering the 4 port injector upgrade. Saving up for relocater box & new shackles to help the ride out. Then driving it into oblivian.
Recently put new headlights & wiring harness, and bedlined the grill & lamp shrouds.
Beef is good...... but that spindle box is hideous........ just sayin'........
Cut that box diagonal and make it a triangle "shelf" if you will.
I actually was going to do that, but without a capable drill press, there's no way to get a properly ovaled hole for the spindle to slip through at that angle.
The box itself is made up of triangled pieces. I took those pictures sitting down so you cant really see it. It's not as big and bulbous as it appears. The front plate is the only piece that's an actual square.
Cut that box diagonal and make it a triangle "shelf" if you will. Kinda like a military antenna mount. That lower edge of the box is gonna catch and dig on rock shelfs/ledges. Cut it at an angle so it'll slide.
Like so.........
Mike -- is your sister in a bad way without wheels? If you can source a tranny I'm sure some of us could get together and get it in while you're gone...
