- Golden, CO
Thanks! I added some fresh solvent, just because it was low. Then, I cleaned housing!Nice action photo! Looks like you are squirting maple syrup on it.
I've had shop privileges for almost a decade. This is the first time I used the parts washer. Yup, it's home built.
After I got it cleaned up, I didn't like the looks of that plastic thang.
I measured the hole (.340") and did something even more sketchy. I tapped it for 1/8" NPT. If you've never cut threads before, this is not the project for learning how!
You may notice there isn't much room around that hole. I couldn't use any of the standard tool holders. I wound up turning the tap with a combination wrench, while trying to hold the tap steady with my other hand. That sunnybeach was rocking all over the place; good way to break a tap! After the tap should have been coming out the back side, it got very hard to turn. I could have tried forcing it; good way to break a tap! I backed it out.
I smeared the threads of the fitting with my favorite sealer, and ran it in the hole. I had a pretty snug interference fit before the threads bottomed out. I think that'll do...
