wolf2600
- Austin, TX
You know the ones I'm talking about.... the same flow/pressure as the stock injectors, but they have a finer spray pattern?
My 99 XJ Sport is needing a replacement fuel pump, and I figured "why not replace the injectors too?". So I was gonna buy a set of whatever the "good" injectors are, have them cleaned and flow matched at RC Engineering, then install the pump/filter/injectors at the same time.
Thanks
Thanks
