Lost_Wrench
- CO
Lots of related threads on this, and likely culprits, so here's my misfire thread. I promise to follow it through with my eventual solve as well.
1996 XJ 4.0 that I've done a lot of work to in the last year, these parts shouldn't be ruled out, but are probably not likely due to recently being replaced...
-New (refurbished and matched) Siemens fuel Injectors
-Champion Plugs, wires, distributor cap
-Head Gasket (old one wasn't bad)
-Crown Automotive Fuel Pump and Fuel Filter
-O2 sensors (both)
-Battery is new and terminals are clean and tight.
All I have done so far is checked the spark plugs in cylinders 1 and 2. They look fine and are properly gapped at .035. I replaced them anyway. No change.
Symptoms: I've owned this Jeep for about 2 years now and it's always had a small "pop" in the exhaust so I knew there was a slight misfire issue but now it's getting worse and threw the codes the other day. I will be testing fuel pressure and swapping the injectors to other cylinders to see if the codes follow them, but I kind of doubt they are the problem with how new my fuel delivery components are now. I recently did my head gasket last winter too, and don't have any overheating issues so I don't think I have bad compression, but that test will be done as well before I start shooting the parts cannon at various things. Anyone have input or other likely (or simple) culprits to check before I get started with serious diagnostics? Thanks!
-O2 sensors (both)
