JeepN4kc
- Blue Springs, MO
Well I dropped the rear diff cover this morning to swap-in fresh gear oil and get a look at the welded rear-end in my new to me XJ.
I found the welds are cracked.
In this pic you'll notice lower-left/upper-right:
Rotate the axle and you'll notice upper-left/lower-right:
I'm an XJ newbie still learning, especially when it comes to welded differentials, so I'm not sure of my options. I've only driven this thing 20-30 miles since picking it up about a month ago. If put new oil in, pop the cover back on, and continue to drive with this going on in the rear I assume it will chew the welds up and really do some damage eventually? Can this be rewelded? Can the spider gears be replaced? Should I just get a new rear-end?
