Welding made easy at Harbor Freight Tools - that was the goal given to the Chicago Electric Welding engineers when they began designing the 90 Amp flux wire welder. This easy-to-use, high quality welder features flux wire (avoiding the requirement of a shielding gas) which helps generate perfect beads and a high Open Circuit Voltage level (31OVC) to ensure clean starts and finishes. Engineered to weld mild, low alloy steel with thicknesses from 18-gauge to 3/16-inch - this home or work-suitable welder will help make a beginner look like a pro.
Chicago Electric Welders at Harbor Freight Tools also deliver quality that matches the quality of the competing brand welders, but at a fraction of the price. How do we know? We put them through punishing side by side tests in our own state-of-the-art test lab - just like those operated by leading consumer magazines. Most importantly, when it comes to quality, we walk the walk - with a 100% satisfaction return policy. Best of all, Chicago Electric Welder's 90 Amp flux wire welder can be purchased at Harbor Freight Tools for the ridiculously low price of $99.99 with coupon. Comparable welders sold by competitors can sell for over $300!
Key features and benefits:
<img height="20" width="20"> No gas or regulators required - completely self-contained <img alt="" height="20" width="20"> Excellent for windy conditions since a shielding gas is not required <img alt="" height="20" width="20"> Runs on standard 120 volt, 20 amp household, single phase power outlet <img alt="" height="20" width="20"> Uses readily available 0.030 to 0.035-inch flux wire <img alt="" height="20" width="20"> Excellent for low and mild alloy steel, stainless steel and nickel alloys <img alt="" height="20" width="20"> Thermal overload protection system includes high intensity warning light <img alt="" height="20" width="20"> Total control of wire feed speeds ensures full weld penetration <img alt="" height="20" width="20"> Rated Duty Cycle - 20 percent @ 90 AC amps <img alt="" height="20" width="20"> Sturdy 6-foot welding cables for welding gun and grounding clamp <img alt="" height="20" width="20"> Everything you need to weld is in the box
Click here to read the reviews from other Harbor Freight customers who've purchased one of our new welders!
