tommyboy
- Elk Grove, CA
is that one of those on board welders? and whats the price and durability as well as performance?
I was just using my "peanut" welder again today (making new seat mounts) and was thinking about this thread again.
As mentioned already, even the cheap HF welder will be good to practice and learn on.
There is lots of info online about how to lay beads and different types of joints, patterns, techniques, etc. There also info about what to look for in the puddle and such. There are even some good quick videos out there. Lay a few beads, see what you get, then refernce that with some of the info out there. Once you actually start playing with things, a lot of what has been said will make more sense.
Check out Lincoln's website and their articles for more reading: http://www.lincolnelectric.com/knowledge/articles/list.asp
One thing that crossed my mind today was "redundancy". I don't put all my faith into a single bead if I can help it. That might not the case for some of these guys who are pros or have high power machines, but for me being a self taught hobby welder, I try and put things together in such a way that there is some redundancy, just in case something might fail. Just a thought.
Ya I've beenreading a lot and maybe tomorrow I'll go get some scrap to practice on. How thick of metal should I get?
Yes http://www.readywelder.com/
But even a 24 volt charger added to the cost would still be much less then any other welder that can weld 1/2 inch in one pass.
Saying that the strongest and cleanest welds are produced by T.I.G welding is a pretty BOLD statement.
No it's not. It's the damn truth. If it's not the cleanest & strongest, then why are ALL aircrafts welded this way? Why does high pressure pipe for nuclear plants and oil pipe lines require at the least one T.I.G. root pass? Why are all custom chopper frames, sandrails, rock crawlers, dragtsers, nascar's and basically anything welded that can't have a weld failure welded by the GTAW process??? Don't comment about something in which you know nothing about.
X3, TIG welding is simply strongest, no question about it. Part of the reason is that TIG produces a smaller heat affected zone, reducing changes in the molecular structure of the surrounding metal that can lead to fatigue and cracks.No it's not. It's the damn truth. If it's not the cleanest & strongest, then why are ALL aircrafts welded this way? Why does high pressure pipe for nuclear plants and oil pipe lines require at the least one T.I.G. root pass? Why are all custom chopper frames, sandrails, rock crawlers, dragtsers, nascar's and basically anything welded that can't have a weld failure welded by the GTAW process??? Don't comment about something in which you know nothing about.
Good info and quite correct. I should have added that TIG is the strongest for the type of things I weld, mainly tubing and small parts. I wish I could take a good welding course to master some different techniques and learn some different processes.This thread, for some reason, lives again and I don't know why. Hasta
I do know that this argument of what type of weld is strongest may interest some so I will throw out my professional opinion based on what I know and see. TIG welding is not simply the strongest weld. I will exclude the many dozens of welding prcess that can be far stronger than TIG and focus on the big three. (Stick, MIG, TIG) TIG welding does not always produce a smaller heat affected zone. It can but that depends on the speed and heat input. MIG tends to beat TIG welding as far as having a smaller heat affected zone because of its higher travel speed and lower heat input. TIG welding is used often times because of cosmetics. It is an excellent process for pipe and tubing and can more easily produce sound welds free of porostiy and other weld defects when compared to Wire welding or Stick welding on pipe or tube. That is why nuclear, food, and pressure piping sees so much TIG welding. It is often used on aircraft because TIG is an overall cleaner, more consistant, and stronger process on aluminum. (that is why it was invented) It is a very clean process which is nice except when you are welding over mill scale or coated steels. That is when TIG welding becomes one of the worst welding process because it has such poor cleaning characteristics compared to the other processes like Stick or flux core welding. TIG welding also has lower penetration than other kinds of welding such as certain Stick electrodes and Flux Core. This of course makes it weaker with certain joint configurations. TIG welding is also more crack prone than some other types of welding due to the fact that it is not a low hydrogen process. In short, you need to make sure your material isn't too thick and/or too cold otherwise your pretty TIG weld could be susceptable to cold cracking or hot cracking because of hydrogen embrittlement. All said, this all makes TIG welding a weaker process in many situations and superior process in many other situations. Depending on the material, position, thickness, and the skill of the person, TIG can be as strong or stronger than many welding processes but it certainly isn't going to considered the strongest best at everything. I have roughly 15,000 hours of TIG welding experience, I am a structural welding inspector, and also a welding instructor. As much as I wanted to not add to this thread that was dead three months ago, I just had to throw my two cents in before 50 people agreed that TIG welding is the strongest with no questions asked. :lecture:
time for bed,
Jeeps
'00 4.0 5sp built and green
