Miller & Lincoln are the most popular and widely used brands. Their quality has been tested for many decades. Both are great machines. I'm a welder by trade and have been for 11 years. The strongest and cleanest welds are produced by T.I.G. welding. Not the easiest to learn, but 300-400 amp macchines will weld material thicknesses from .005" up to 1 inch or even more with the right beveling, and multi passes. By far the easiest to use and cheapest is a M.I.G. welder. The Miller 180 would work great for anything you'll have to weld on your XJ. Again, if you're welding material thicker than 1/4'', you should bevel your work to get a solid root in your welds, plus miltiple passes(2-3)over 3/8'' thick. This really only applies to fillet joints like a "T" joint.
