XJWheelie
- Murfreesboro, TN
I'm assuming that at some point, someone has put holes in their floor to let water out after you get in too deep. Should I just drill a hole or maybe cut knock out the plastic pieces and leave the hole like it is, or should I put some kind of valve or cover over them that I can open when I need to?
At the moment I've got some kind of leak on the passenger side that allows water to come when it rains, so I've got to do something anyway. I can't find any problem with the door seal, so I'm thinking that the water might be coming in through the vents.
