wanted driveshaft and other stuff
88xjchief
Connecticut
I need a front driveshaft for a manual transmission, the boot that bolts to the floor on a manual tranny, passenger side axle shafts for a d30 doesnt matter if its vacuum disconect, and a hinge for the rear hatch of a 96-xj.
I've got an outer shaft (the one from the vac disconnect to the ujoint) and a stub shaft for a d30 you can have free if you pick it up. It's got some light surface rust on it but could be cleaned up pretty easily. It's got a U-joint included but I'm not sure if it needs replacing, flexes freely but may be missing a zerk.
