Wagoneer Front D44 & Rear Dana 60 Spools 5.38 Gears Solid Covers
Moo Moo Jeep
Colonia, NJ
For sale used Wagoneer front Dana 44 axle with a lot of new parts. It has spring over axle set up for Wrangler YJ. I bought this axle few years back with the plan to get brackets welded so it’d fit my Cherokee XJ but it never happened. As far as I remember all the parts except for housing and axle shafts are new. Pictures are not the best because axle is still in crawl space. I’ll take better pictures once I’ll get it in my garage. Then I’ll open the cover and take pictures of the gears too.
Bolt pattern 6 x 5.5”. WMS-WMS is 60 ¾”. Diff on the driver side. I priced all the parts and labor to figure out would it would cost to build it. Labor is my guesstimate but most likely it would be more than $500.
Used D44 axle 250
New Solid Diff cover 70
New Warn Hubs 100
New 1-ton steering 240
New Calipers & pads 150
New Rotors 50
New 5.38 gears 160
New Master Install. Kit 100
New Spool 150
Labor 500
Total 1770
I’m asking $1200 OBO for D44. Located in Colonia NJ 07067. No shipping. Pictures are on CL: https://newjersey.craigslist.org/pts/6020079167.html
I also have rear Non Full width Dana 60 bolt into XJ. I'm not 100% sure I want to sell it. If you interested make me an offer on both axles. I'm definitely not selling D60 before I sell D44.
D60 Specs
[FONT=&quot]Semifloat
5.38 Yukon gears
Full spool
35 spline Moser alloy shafts
6 on 5.5" lug pattern
1310 u-bolt yoke
Monte Carlo disc brake calipers with fairly new pads
Rotors are from a 88 Chevy 1500 regular cab 2wd
Regular ol' Dana 44 (timken set10) outer bearings and wheel seals.
62" WMS-WMS
Solid diff cover
Ruffstuff XJ antiwrap perches
.[/FONT]
