Moo Moo Jeep
- Colonia, NJ
For sale used bolt on XJ rear Dana 60 axle. It has 35 spline (1.5" dimeter) Moser axle shafts and 5.38 gears so you can run up to 38-40" tires with this axle. Bolt pattern is 6 x 5.5". WMS to WMS is 62" so it's only about 1.5" wider than the stock Cherokee axle. Below I listed and priced all the parts and labor to figure out would it would cost to build this axle from scratch. Labor is my guesstimate but most likely it would be even more than $1000 because only the cost of setting up gears is about $400-500 and then you have to add welding which is not cheap either.
Spects/Cost to build:
Used Dana 60 axle $400-500
6x6.5" Bolt Pattern
WMS to WMS 62"
Moser 35 spline (1.5" thick) axle shafts $370.
Yukon 5.38 gears $280.
Full Spool $160.
Master Install. Kit $130.
1310 U-bolt Yoke $60.
Solid Diff cover $105.
Regular Dana 44 Timken Set 10 Bearings and Seals $50.
Ruffstuff Antiwrap Perches $35.
High Clearance Shock Mounts $30
Brake mounts ???
Monte Carlo disc brake calipers and pads $120
88 Chevy 1500 regular cab 2wd Rotors $60
Labor $800-1000
Total $2600-2900
Craigslist price $1800.
price $1600 OBO.
Located in Colonia, NJ 07067. Local pickup and cash. I'd take PayPal if you willing to pay 3% PayPal fee. No shipping. I might travel little bit to meet half way for right price.
Craigslist ad and pictures: https://newjersey.craigslist.org/pts/6144974002.html
I'll take better pictures once I'll move it from crawl space into my garage. Then I'll take pictures of the gears and spool too.
6x6.5" Bolt Pattern
WMS to WMS 62"
Full Spool $160.
Brake mounts ???
Labor $800-1000
Total $2600-2900
price $1600 OBO.
